Necessary To Remove Windows When Adding Flashing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 12:32 PM   #1
Necessary to remove windows when adding flashing?
I know the correct way to flashing is to include a piece across the bottom of the window opening before the window is installed. Is it necessary to remove windows when adding flashing or is there a technique to use where you don't have to remove the windows? Thanks for the help.
xludan is offline   Reply With Quote
Old 05-29-2009, 05:54 AM   #2
Assuming nailing fins.........the bottom flashing should be under the fin.
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 06:10 PM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 12:48 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
