Old 02-09-2007, 01:22 AM   #1
yummy mummy's Avatar
Default Necessary to insulate basement ceiling between joists?
Is it necessary to insulate between the joists in my basement?
What would be the advantage or disadvantage?
The heating vents in the basement are in the ceiling.
The first floor has hardwood everywhere. It is not cold.
Would insulating make the basement warmer?
Also, how would this interefere with the pot lighting that I plan on installing?
I know there are pot lighting that are made for insulated ceilings.
Thanks for any advice.
yummy mummy is offline   Reply With Quote
Old 02-11-2007, 05:35 PM   #2
Noise a problem in your house? In a duplex I am working on for my parents, I had to gut the basement out, not insulated at all down there, you can hear everything the people are saying in the other side of the duplex upstairs like you were in a room right next to them with a door open. So it's getting insulation on the ceiling.
AntiBling is offline   Reply With Quote
Old 02-11-2007, 05:45 PM   #3
concretemasonry's Avatar
Insulating the floor will not save you any money on energy. It only makes sense if you have a sound problem.
There are many better solutions to sound problems than the worthless pink fluff.
concretemasonry is offline   Reply With Quote
Old 02-11-2007, 06:59 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
No, it is not.
However, you should insulate the areas of the joist bays that are on the outside of the area. (In the inside area of your rim joists, above your mud sills located on your foundation walls)
These are the outside/exterior wall areas of the basement ceiling joists.
The advantage of doing the the area mentioned above is for heat.
As far as insulating between your joists on the inner areas, this is only done for sound deadening. Example: Hardwood floor above on the 1st floor, lots of kids running around the house, home theater in basement....
Insulating that area is optional for your needs...
Insulating the areas above your basement rooms would not make those basement rooms warmer.
Also, how would this interefere with the pot lighting that I plan on installing? I know there are pot lighting that are made for insulated ceilings.
Insulating the floor joists would effect the 'can' (recessed) lighting by the fact that you would have to spend more money purchasing 'insulated' (IC-rated) recessed lighting.
These can lighting units have an outer layer of metal (box) that keeps the hot lighting elements and raised lighting temparatures away from combustable materials in the ceiling. They are required by CODE when there is insulation in the ceilings that the cans will be installed in. As mentioned they do cost more... (example: $5.00+ vs. $24.00+ - U.S. )
- Build Well -
Old 02-11-2007, 10:31 PM   #5
Thanks for all the great information.
I will not be insulating the ceiling joists as sound is not an issue.
I would have considered it if it would have made the basement a little warmer but as it is I will not be insulating.
Atlantic:
I have insulated the joist bays.
Old 02-15-2007, 06:45 PM   #6
Do I have to put a vapor barrier in the joist bays?
I have insulated them.
Old 02-15-2007, 08:12 PM   #7
If they don't have the paper faced vapor barrier...then sadly (more work).....yes....
- Build Well -
Old 02-15-2007, 11:44 PM   #8
.................more work, yes.................
Should I also put that red colour tape (I think it's some sort of duct tape?) where the seams overlap when using the vapor barrier?
Boy, do I have a lot of questions............
Thanks........
Old 02-16-2007, 05:08 AM   #9
Thanks........
Might as well...
- Build Well -
Old 02-06-2009, 03:27 PM   #10
how did the insulation work out?
degas43 is offline   Reply With Quote
Old 02-06-2009, 06:23 PM   #11
I did not insulate the ceiling, only the joist bays.
I did insulate all of the exterior walls and vapour barrier.
I have come a long way since then. I am starting to paint. Then all I have to do is lay some ceramic tiles. Should be done by Christmas.......
Old 02-06-2009, 08:51 PM   #12
tomstruble's Avatar
you should post some pictures
tomstruble is offline   Reply With Quote
Old 02-07-2009, 01:19 AM   #13
I will post some pics when I have completed it.
I have posted pictures as I have progressed. If you search, you will see my last ones of my taping.
I have not posted any since. But hopefully, soon I will be able to show the finished project.
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next thing on our list is going to be the garage band joist air barrier. What that is... Read More »
Hi, this is Jon and in this clip I'll be answering the question, "which light do I buy?". In our basement we only have two of these in-ceiling can lights and that is just not enough light to suit our needs. Now as we go about the process of installing... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next one that we are going to cover on this list is going to be the air barrier and all... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
garage ceiling joists josh123 Carpentry 6 07-15-2009 01:07 AM
Spray foam insulating joists in basement? peethree Building & Construction 6 08-24-2007 09:21 AM
basement ceiling joists-how to know if they are level? yummy mummy Building & Construction 22 02-06-2007 10:16 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 10:27 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 01:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
