Natural Stone Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 08:31 PM   #1
Question
natural stone wall
I just built a glass porch that I want to cover the skirting with thin natural stone.I have h-beams for joists and welded angle iron frames to hold pressure treated 3/4 plywood to cover the sides which I bolted to the angle iron.the skirting is only about 2 ft high.I have some natural stone that ranges from 1/2" to 1" thick and was hoping to cover the plywood with.My question is whats the best way to go about this?Do I need to prep the plywood with something first?thanks
revid is offline   Reply With Quote
Old 09-15-2011, 07:53 AM   #2
Rewards Points: 5,336
Cover the plywood with tar paper and put a galvanized diamond lath on the tar paper. Adhere the stone to the lath.
Ron
B. Franklin 1759
Old 09-15-2011, 08:52 AM   #3
What would you suggest to stick the natural stone on with?premix grout,thinset.any particular kind of grout?do i wet the stone first before grouting?
Old 09-15-2011, 01:22 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No grout of any kind especially a premixed grout.
Thinset mortar could be used but will droop and run severely.
Better products would be Type S Mortar or Type N Mortar. I would use Type N. You have no special requirements other than the project is out doors.
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 07:39 PM
Field Stone and Mortar Wall, will it be stable? NorskeDiv Landscaping & Lawn Care 4 07-14-2011 11:18 AM
decorative stone facade over retaining wall denemante Landscaping & Lawn Care 1 06-25-2011 07:07 AM
dry stack natural stone retaining wall diy001 Landscaping & Lawn Care 17 06-20-2011 12:57 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
