Natural Stone Exterior Application With A Twist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 04:04 PM   #1
natural stone exterior application with a twist
new guy. Hopefully I am following protocol. We are going to be installing 4.5 feet high from the ground up of natural stone at my house. 2 of the walls are stucco only. The other two have 3 horizontal boards that start at 12 inches from the ground and are 2.5 feet. When removed I have studs 16 oc then building paper. Basically a gap of 2.5 feet between stucco bottom and stucco top. Lots of info out there but here is what I am thinking. Plywood sheathing..vapor barrier....shims.....1/2" Durock that is plumb with top and bottom. Prep the stucco above and below.....seal the joints....then stone. Any feedback is much appreciated. Thanks, John
fairsnpomona is offline   Reply With Quote
Old 08-28-2012, 07:27 AM   #2
Rewards Points: 3,130
I wouldn't use cement board (Durock). Around here, most masons use metal lath with a scratch coat instead.
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 09:27 AM
Installing natural stone kitchen backsplash kathybc Flooring 2 01-22-2012 07:36 PM
natural stone grouting mess jpgiat Tiling, ceramics, marble 1 10-09-2009 02:20 PM
Natural stone veneer Jer General DIY Discussions 7 02-03-2009 01:33 PM
