Narrowing Exterior Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 06:54 AM   #1
Rewards Points: 398
Narrowing exterior opening
I currently have a 9ft exterior opening with a 3 panel sliding glass door. I would like to narrow it to 6ft to add a french door. This will allow me to have a little extra room for a kitchen expansion.
I don't want to replace the header. My plan is to add 1 1/2 ft base plates to each side. As far as framing goes, I was just going to add two jack studs to both sides of the french door. Do you see any problems doing it this way? I will need to get it inspected.
Malcolm is offline   Reply With Quote
Old 09-19-2013, 06:59 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Thats the way I would do it. No reason to replace the header. How will you match the exterior finish?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-19-2013, 11:41 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
sounds like a plan to me
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-19-2013, 01:13 PM   #4
cortell's Avatar
Rewards Points: 504
Works for me. Just make sure the expanded kitchen does not require a cavity directly in that 18" run (e.g, plumbing that needs to shoot up the wall).
Much like chess, successful construction requires thinking ahead three or four moves :-)
cortell is offline   Reply With Quote
Old 09-19-2013, 03:14 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
also when you put the new plates down to make it smaller make sure their in line with the existing wall.. if their off kilter and you go to hang a door in the opening it will create a major headache
woodworkbykirk is offline   Reply With Quote
Old 09-19-2013, 03:24 PM   #6
Rewards Points: 398
It's board and batten. I replaced a lot of it on the backside last year. I'm will hide the cut with with a batten.
Old 09-19-2013, 03:26 PM   #7
Rewards Points: 398
Thanks for the help. I appreciate it.
narrowing door frame kittykat Windows and Doors 3 11-24-2011 09:55 AM
Narrowing Down My Furnace Problem colu41 HVAC 10 10-29-2011 02:06 PM
