Name Of A Type Of Brick? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 06:17 PM   #1
name of a type of brick?
Hi there! So this is a random post and I'm sorry if I am intruding on your forum...I am just looking for any help I can find!
So I guess my googling skills are not up to par because I have been trying to find out the name of these cylindrical bricks my mom has and I can't find what they are called! My father (who has since passed) had bought about 50 of them to make a makeshift wine cellar...we now want to get rid of them, but I don't know what to call them when I post them on craiglist to (most likely) give away. I know I can just post the pics in craigslist and someone will probably want them, but I am really curious as to what they're called and how much they are since I can't seem to find anything similar online. They are about a foot long, and about 5 1/4 in in diameter. I've attached pics for visual reference. Any help would be awesome...thanks all!
jantan is offline   Reply With Quote
Old 09-30-2010, 06:46 PM   #2
Chicago, IL
Michael Thomas's Avatar
Ceramic flue tile:
http://www.superiorclay.com/flue-liners.php
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-01-2010, 01:43 AM   #3
Michael Thomas you're my hero! that link to the website you posted also had a category called "wine storage tiles" that had the exact same thing with the same dimensions that I was trying to find...thanks so much!!
Old 10-01-2010, 06:34 AM   #4
Chicago, IL
The difference is that flue tiles are round, square or rectangular, while "wine storage tiles are often hexagonal:
and are often glazed with a decorative finish.
Old 10-01-2010, 08:37 AM   #5
Concrete & Masonry
Rewards Points: 636
Good job Michael, the same manufacturer I would have posted.
Technically, I'd call them 4" clay tile. They were used for many years for drainage, underground plumbing, etc....
jomama45 is offline   Reply With Quote
Old 10-01-2010, 08:50 AM   #6
Rewards Points: 582
Joe,
Don't your flue liners have spigots and rebates?
stuart45 is offline   Reply With Quote
Old 10-01-2010, 08:59 AM   #7
Concrete & Masonry
Rewards Points: 636
Originally Posted by stuart45 View Post
Joe,
Honestly Stu, I'm not sure about your terminology.
Maybe you mean what we would call a "hub" for a slide in connection, or a "thimble" for a 90 degree branch?
Either way, clay flues, especially round, are becoming increasingly uncommon here in the states. Rarely ever are full masonry FP's built anymore. Most folks love to cozy-up to the speed of installation and cost savings of zero-clearance "tin boxes".
Old 10-01-2010, 09:28 AM   #8
Rewards Points: 582
Joe,
in the picture ou can see the rebate for the spigot of the next liner to sit in.
Old 10-01-2010, 09:36 AM   #9
Concrete & Masonry
Rewards Points: 636
Joe,
Well, then the answer is simply NO. Never seen a flue tile like that, our's just stack over each other and can be flipped end for end. I can see the clear advantage to that kind of joint though.
Old 10-02-2010, 07:42 PM   #10
Around here we call them round flue liners or tiles and they come with a shiplap joint same as Stu's
4th gen
4th generation is offline   Reply With Quote
Old 10-02-2010, 08:25 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
so, would they simply be stacked and aligned by the installer with some sort of masonry mud as a bonding material?
if so, sure seem like those (spigots and returns (gotta love the Brits)) would be very beneficial.
Old 10-02-2010, 09:20 PM   #12
I usually use CPD stove and furnace cement or fireclay between the flat ones
4th gen
Old 10-03-2010, 06:31 AM   #13
Chicago, IL
The UK is way ahead of the US s regards some chimney construction details, as for example the common use of through-wall flashings in chimneys.
Old 10-03-2010, 08:03 AM   #14
Concrete & Masonry
Rewards Points: 636
Yes, typically with fireclay for me.
I agree.
Attaching Porch shed roof to Brick Veneer ApexTiger Building & Construction 46 02-16-2010 05:28 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 05:57 AM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 10:06 PM
