-   -   Nails - what size(s) to use for light frame construction? (http://www.diychatroom.com/f19/nails-what-size-s-use-light-frame-construction-92605/)
J S Machine 01-17-2011 12:16 PM
I'm fixing to do some light wood frame construction. From what I can find, 16d nails seem to be the nails I need. I've done some building of things before and used various nails, but never paid attention to what is correct.
I don't have a nail gun so I will most likely be driving every one of these by hand. I see that cement coated is easier to drive. I'm just not sure what I need.
3.5" nails seem like a good size, but I don't think those will work when nailing two 2x4s together for instance. With a combined board cross section thickness of 3" (1.5+1.5) I would have .5" of nail sticking out the back side. I know this isn't right is it?
On the other hand, a 3.5" nail seems okay for toe nailing or other nailing situations where I might need the extra length.
Suggestions?
BigJim 01-17-2011 05:53 PM
Suggestions?
12d coated hand nails for framing, you would hate using 16d for the very reason you stated, they are too long.
bob22 01-17-2011 07:22 PM
I was told once that a general rule of thumb was to use a nail 3x's the thickness of the thinner piece of wood being joined by the nails.
loneframer 01-17-2011 07:27 PM
When doubling 2x members, I like to use 12s and clench the nail point over to pinch the boards. 16s tend to do alot of splitting. 8s are my fastener of choice for toe nailing studs, for instance.
benjamincall 01-17-2011 08:36 PM
Check out pages 2-4 of chapter six:
http://www2.iccsafe.org/states/newje...l_Frameset.htm
jklingel 01-18-2011 04:49 AM
16d splitting depends on the hardness of the wood and whether or not you are at the end of a stud. at the ends, do your best to nail across different grains, as opposed to the nail being parallel to the board; that pretty well guarantees a split at the end of a stud. you can always drill the end of the board, too, but that is an obvious pita and an emergency deal. if nailing two studs together, angle the nail instead of going straight across. it will hold better, too, esp if you alternate the direction in which you nail.
