Nails Vs. Screws For Ceiling Furring Strips - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 10:06 AM   #1
Nails Vs. Screws For Ceiling Furring Strips - Pic Included
I'm planning to install two layers of 5/8" drywall + Hat Channel + Isolation clips on the ceiling of my home theater. I have an 18" paralam that bisects my room, that hangs down 2" further than the rest of the ceiling, so I am adding 2x4 furring strips so that my first layer of drywall is ~5/8" below the beam. Here's a photo of my current progress and the offending beam.
My question, I've been using 2-1/2" deck screws to attach the furring strips, but it's slow going. I'd much rather use 2-1/2" framing nails as the nail gun will get the job done quicker. I'm just not sure about the holding strength of the nails for the weight that I'm planning to put up there.
Can I use just nails, or should I put up my furring strips with nails and come back and put in 3 or 4 screws in each 2x?
Thanks in advance!
emagsamurai is offline   Reply With Quote
Old 11-30-2012, 10:19 AM   #2
Rewards Points: 13,300
Ring shank nails would work.
How are you driving the screws?
I'd be using my impact screw gun or a corded drill not a cordless drill if that what you using.
Old 11-30-2012, 10:22 AM   #3
I've been using my cordless as it drives the screws faster (and is lighter than my corded drill ). My impact works great, but it's slower than the drill. It seems to switch to impact as soon as the screw hits the I-beams. I guess the wood is pretty hard. Since I'm working overhead, fast is good
Old 11-30-2012, 03:57 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
gun nail it. 4x faster than screws and cheaper
woodworkbykirk is offline   Reply With Quote
Studs vs Furring Strips In the Basement brockmiera Building & Construction 9 10-12-2012 11:11 AM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
Drywall - Nails or Screws? digthisbigcrux General DIY Discussions 6 03-20-2007 05:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
