Which Nails To Use On Facia Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2008, 01:27 AM   #1
Which nails to use on facia boards
Do I use 8d galvanized ring shank or the twist ones?
UFoPilot is offline   Reply With Quote
Old 10-11-2008, 05:56 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My Suggestion: 8d Hot Dipped Galvanized ringshanks.
- Build Well -
Old 10-11-2008, 06:16 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Good choice! suggested from above.
Old 10-11-2008, 08:27 AM   #4
the Musigician
DangerMouse's Avatar
anything wrong with twist? is there code on this? just curious.... ringshanks are a real bytch to remove if needed down the line.
DM
Old 10-11-2008, 08:30 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Typically, if it's difficult to take apart means it was put together correctly to begin with but if you need to get them out, nail nippers usually do the job.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-11-2008, 10:08 AM   #6
the Musigician
you mean nip the heads off? whenever i try to pull one, it takes out big chunks on the way! lol
DM
Old 10-11-2008, 11:12 AM   #7
I have gas!
Not to nip the heads off, but to grab the shank of the nail and pull it out. Something like the Husky sold at HD.
http://www.homedepot.com/webapp/wcs/...atalogId=10053
Old 10-11-2008, 11:42 AM   #8
Registered User
Termite's Avatar
Twist nails are not for framing applications and are better used in securing deck boards. 8D ring shanks will work well for securing the fascia if it isn't too thick. If it is thicker, go with a longer ring shank to get good penetration into the rafter tail.
Old 10-11-2008, 11:51 AM   #9
Thanks for the replies guys...
Old 10-11-2008, 07:05 PM   #10
If you are in Florida use screws, nails (all kinds) glue, straps and wire and put in GPS tracking so that you can find it after the hurricane has passed.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-11-2008, 08:08 PM   #11
I'm in Kansas...we get tornadoes here. What brand GPS?
Old 10-11-2008, 08:20 PM   #12
Doesn't matter cause it won't be in Kansas anymore Toto! Couldn't resist.
Old 10-11-2008, 09:34 PM   #13
Registered User
Termite's Avatar
Hurricane schmurricane. You can build a house to resist a hurricane. You cannot build a house to resist a tornado (unless it is solid concrete or an underground bunker). Here in Kansas, we build houses to resist hurricane-force peripheral winds that happen a half-mile away from a tornado.
Old 10-11-2008, 10:04 PM   #14
Yea, and hurricanes get all the press.
Tornado's are much more violent and have much higher winds. It is not uncommon to see 200+ mph winds.
Plus you can't plan for a tornado and move to another state till it's over.
The negative pressure is what does on most homes. The positive pressure that comes in at ground level then rushes up towards the negative pressure at the higher levels and taking anything it can with it.
When I was 16 in Minnesota I was coming back from a dance with my buddy. We saw a tornado come right at us. I pulled off the road into a ditch and we crawled under the car. It came within a 100 yards of us and I'm here to tell you, I was scared.
The wind was incredible and the noise was something I will never forget. Once it was gone it was real quiet.
From the information I know now it was a class 1 more than likely. Just a small one. I can't imagine what a big one is like.
Here's a question for you. Why don't codes require a storm shelter for al; homes including and especially modular homes??? I remember when they required tie downs but that just isn't enough from where I sit.
Old 10-11-2008, 10:05 PM   #15
Custom Cabinet Maker
Ya meant those 2 acre tubular kinda silo underground critters out there?
Aint never heard of a tornado hurtin them
skymaster is offline   Reply With Quote
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 09:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
