Nails For Hardiplank - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2007, 04:27 PM   #1
Nails for hardiplank
I am having some trouble finding stainless nails for my hardiplank project.What's next best,hot dipped galvanized?
white29 is offline   Reply With Quote
Old 09-26-2007, 06:42 PM   #2
Mod / ArchiBuilder
Cole's Avatar
GENERAL FASTENING REQUIREMENTS
Fasteners must be corrosion resistant, galvanized, or stainless steel.
Electro-galvanized are acceptable but may exhibit premature corrosion.
James Hardie recommends the use of quality, hot-dipped galvanized
nails. James Hardie is not responsible for the corrosion resistance of
fasteners. Stainless steel fasteners are recommended when installing
James Hardie® products near the ocean, large bodies of water, or in
very humid climates.
Cole is offline   Reply With Quote
Old 09-26-2007, 06:55 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I don't understand why you are having a hard time finding Stainless siding nails?
Are you looking for "loose" nails or Nails for a pneumatic siding gun?
One of our current jobs is installing a complete strip off and installation of Hardie-board. We have Stainless Steel coils for our Bostitch N66C siding coil nailers, and also some loose ring shank stainless nails that we purchased from H.D.
Are either of those what you have been looking for?
As mentioned by Cole, the other alternative is Hot Dipped Galv. (Stay away form using Electo-galv as they tend to bleed and stain in a short amount of time)
- Build Well -
Old 09-27-2007, 06:43 AM   #4
I'm just trying to find loose nails,no nailer.My local home said they are not stocking them anymore.I'll keep looking. I'd prefer to use them since we get alot of precipitation and humidity here. Thanks.
Old 09-27-2007, 09:49 PM   #5
remodeling pro
True hot dipped would be next, but that would resign you to hand nailing, as true hot dipped are too rough to be collated for nail guns. As Atlantic suggested, most contractor suppliers , and some big box locations, carry a selection of often used nails. They are also available online or catalogue, check out Manasquin Fasteners just for one. Of course be prepared for sticker shock compared to typical "galvanized" gun nails.
troubleseeker is offline   Reply With Quote
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 09:25 AM
Rusting nails on exterior firsthomegal Painting 7 05-28-2007 05:15 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
Deck nails jimgibson Carpentry 12 10-09-2005 02:22 PM
