Nails - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2008, 01:19 PM   #1
analogmusicman's Avatar
Rewards Points: 560
nails
I've got a framing nailer (compressed air) are all nails that fit framing nailers coated so they can be used outdoors or are there special ones?
tnx,
analogmusicman is offline   Reply With Quote
Old 11-29-2008, 02:11 PM   #2
must use treated nails acq. or they will rust.
chad4290 is offline   Reply With Quote
Old 11-29-2008, 02:46 PM   #3
knewbie
curapa's Avatar
Look for hot dipped galvanized for exterior work, they are close to double the cost of regular bright smooth nails.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 11-29-2008, 03:46 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
tnx,
No, you will need to purchase Hot dipped Galvanized (as already stated). These will cost a bit more that the 'brights" (non-treated).
- Build Well -
Old 11-29-2008, 06:36 PM   #5
Registered User
Termite's Avatar
Don't confuse coated nails with those for outdoor use. Phosphate or glue coated nails are not for exterior use.
In treated lumber, you must make sure that you get hot dipped galvanized nails, not electro-galvanized.
Old 11-29-2008, 07:31 PM   #6
Rewards Points: 1,016
"Hot dipped" galvenized or stainless steel. Stainless steel if you are a costal area. You can usually find the hot dipped variety locally for nailers, stainless steel via a Google search.
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
cut nails ugabulldog Flooring 2 04-23-2008 11:19 AM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 09:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
Deck nails jimgibson Carpentry 12 10-09-2005 02:22 PM
