Nailing Two 2" X 4" Together ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 12:54 PM   #1
Rewards Points: 85
Nailing two 2" x 4" together ?
Hello,
I need to nail one 2" x 4" on top of another 2" x 4". I was thinking about using 5" spiral nails but not sure if it's enough ? I need to extend the height of a frame/soffit that was made to retain keep the batt insulation in place.
Should I use tie plates instead of simply nailing the 2" x 4" together ?
westbank is offline   Reply With Quote
Old 10-09-2013, 01:00 PM   #2
Rewards Points: 502
Might bounce if you nail it?
Can you screw it using 4" screws (drill 1" dia holes 2" deep first as countersink).
tony.g is offline   Reply With Quote
Old 10-09-2013, 01:14 PM   #3
cortell's Avatar
Rewards Points: 504
When framing an interior soffit/bulkhead, I like to use a combination of screws and common nails. The nails provide the shear strength (which the average screw has little of), and the screws provide the pull out strength (which nails have little of). The sheetrock exerts a downward load on the framing, and that puts the nails' pull-out strength to the test. Actually, it's not so much the drywall I worry about, but that someone might put a screw eye into that framing and try to hang something heavy. With a few screws, I breath easier.
In your case, I would do the same. Use both nails and screws. The screws don't have to be rated for structure (that would be overkill in this case, since they're basically just acting as a backup), but they should also not be drywall screws. I have a preference for SPAX screws.
cortell is offline   Reply With Quote
Old 10-09-2013, 01:33 PM   #4
Rewards Points: 702
Where on earth did you find lumber that flat?
If the next 2 pieces aren't that good there is an easy method of pulling them together.
SeniorSitizen is offline   Reply With Quote
Old 10-09-2013, 01:40 PM   #5
Rewards Points: 85
It's hard to find long wood screws but I was to find 5" deck screws. The shear strength seems to be close to regular wood screws.
Initially I was thinking of using only screws but a mix of both nails and screws could be even better.
Old 10-09-2013, 01:47 PM   #6
Rewards Points: 13,276
Why not just use one 2 X 8 and skip all the work?
Old 10-09-2013, 01:48 PM   #7
cortell's Avatar
Rewards Points: 504
Sorry. Why do you want 5" screws or nails? 3" is all you need. You just need to fasten one 2x4 to the other, right? I wouldn't try to sink the fasteners into the cripple stud ends that the first 2x4 is fastened to. That's just going to increase the chances of splitting those studs, which will weaken the connection.
Rule of thumb: a nail should be no closer than 1/2 its length to another nail and no closer than 1/4 its length to the edge of the wood.
Old 10-09-2013, 01:50 PM   #8
cortell's Avatar
Rewards Points: 504
Wait a minute... which way are you attaching them. The picture is ambiguous as it doesn't show depth.
Old 10-09-2013, 02:11 PM   #9
GBrackins's Avatar
Rewards Points: 2,108
you could use tie plates or a piece of plywood
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
westbank (10-09-2013)
Old 10-09-2013, 02:12 PM   #10
Rewards Points: 85
I wish but the 2" x 4" framing is currently nailed and glued to concrete walls.
Old 10-09-2013, 02:18 PM   #11
Rewards Points: 85
Sorry for the confusion. I need to nail/attach the 2" face with the other 2" face of the 2" x 4". So since a 2" x 4" is 1.5" x 3.5", it would be 7" high and would require screws of about 4.5" to 5".
Old 10-09-2013, 02:20 PM   #12
Rewards Points: 85
Didn't think about using plywood - that's good idea. I was thinking about the ties but they are not cheap.
Old 10-09-2013, 02:30 PM   #13
cortell's Avatar
Rewards Points: 504
Sigh. This is what I think of when I hear "soffit", so extending the depth of that would mean *face-nailing* one 2x4 to another.
Disregard my off-point advice
Old 10-09-2013, 04:28 PM   #14
Unpressure treated wood should not have been used in direct contact with the concrete.
fat (2" circumference) 4" rollers vs. regular hot dog amakarevic Painting 4 04-21-2013 07:27 PM
How to patch around a 2" x 4" hole in back of furnace darlingm HVAC 16 08-22-2011 07:22 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
4" PVC to 4" Lead Bend solidhomes Plumbing 0 07-20-2010 01:36 PM
do they make a PVC 4" "T" with a 2" off the side? What have I done Plumbing 5 08-24-2009 05:37 PM
