Nailing Subfloor To Rimboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 12:24 AM   #1
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Nailing subfloor to rimboard
Rim-board being used 1-1/8
http://ilevel.com/literature/TJ-8000.pdf
First time ever working with this stuff and even though the pdf says its ok, is nailing the subfloor into this rim-board ok ?
It seams like its only gonna split being a compressed type board thing. Theres one 22' length which runs parallel to the joist with still needs to be nailed. When i layed the subfloor (3/4 T&G plywood) at each plywood seam i nailed a scrap of the joist between the walls top-plate and the sheets, but have not nailed down into the rim-board yet. Also added a scrip of the joist in each corner.
Being the pdf says its ok, i guess that i'll do it tomorrow, just would like ot know peoples opinions and experiences.
iMisspell is offline   Reply With Quote
Old 10-21-2008, 07:43 AM   #2
Registered User
Termite's Avatar
Nothing wrong with nailing through the subfloor into the rim material. Just use 8d's.
Tags
ilevel , nailing , rim board , rimboard , subfloor
Buidling code for deck and nailing schedule Jozee Building & Construction 7 10-01-2008 12:46 PM
Windows Nailing Fins Kain Dillon Building & Construction 3 06-16-2008 02:46 PM
properly nailing down 1/2" osb sheeting over lath FISH275 Roofing/Siding 2 04-08-2007 12:49 PM
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 07:33 AM
