Nailing Studs To Sole Plates - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 08:50 AM   #1
Rewards Points: 260
Nailing studs to sole plates
I'm guessing galvanized nails need to be used to nail the studs to sole plate because it is pressure treated lumber. Is this correct? I can't tell if that is what framers are using or not. It is hard to tell. This is for toe nailing.
bluefitness is offline   Reply With Quote
Old 12-15-2008, 09:19 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you are correct. Get hot-dipped galvanized, not electro-galvanized.
- Build Well -
Old 12-15-2008, 12:11 PM   #3
Registered User
Termite's Avatar
Correct! Definately must be hot-dipped galvanized.
Old 12-15-2008, 11:32 PM   #4
Rewards Points: 260
What happens if regular nails are used? Is this a major concern? I can't tell if galvanized nails were used or not.
Old 12-15-2008, 11:38 PM   #5
Registered User
Termite's Avatar
The ACQ treatment in the wood will eat the non-galvanized nails rather quickly (a few years or less in many cases). Definately not something to mess around with.
Most hot-dipped galvanized nails will be dull looking, almost like they've been sandblasted. If they're shiny, you're probably dealing with either "slicks" or electro-galvanized nails, neither of which are good enough.
Old 12-15-2008, 11:50 PM   #6
Rewards Points: 260
The soles are CCA (25 - 30 years old).
Old 12-15-2008, 11:54 PM   #7
Registered User
Termite's Avatar
CCA is corrosive and the code requirement is still for hot-dipped, however CCA isn't nearly as corrosive as ACQ. I don't think I'd lose too much sleep over that.
why use PT lumber for sole plates on concrete ? amakarevic Building & Construction 7 07-30-2008 07:15 AM
small cracks in PT sole plates on concrete amakarevic Building & Construction 14 07-23-2008 02:48 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 07:14 AM
toe nailing studs on the 2 side amakarevic Building & Construction 3 07-19-2008 11:48 PM
power-actuated nail size for sole plates amakarevic Building & Construction 4 06-03-2008 02:12 PM
