Originally Posted by WShawn
I have a Porter-Cable FR350 framing nailer which has served me well in this project. Is there a type of nail that I can use in this framing nailer that would work for this siding application? Grip Rite makes "Exterior Galvanized" 6D 2"x .113 common nails with a ring shank. Would these work?
No, do not use that gun. The reason being is that you need the nail head to sit tightly against (bot on top of) the
surface of the siding board. This can be done with both, siding-coil-nailers and also roof-coil-nailers, as they are designed to NOT sink the nail head into material. In the case of any framing nailer (like the FR350 - we have 4 of them too), this gun will drive the nail head below the surface of the materials (lap siding). This will obviously not hold, or attach the board in the manner that a full head nail, snug on the surface will do, and how the boards need to be properly attached.
If I can't find anything that would work in my nailer, how hard would it be to hand nail 155 pieces of this stuff using loose nails?
You can screw the siding in too.
Also, what would you suggest for a starter strip? Would you rip strips off of a piece of HardiePlank (wearing a respirator) or could I just rip strips off of a piece of framing lumber or P/T lumber?
You could use rips of your hardieplank, or some rips of cedar siding.
I've never built anything this big before. It's been a fun challenge, but slow-going at times.
Good Luck on your project Shawn.
Also, HD sells a very inexpensive 7 1/4" Cement board cutting blade for skill saws.
FWIW: When we install Hardieplank, we:
Set up:
A table saw with cement cutting blade.
Compound saw with cement cutting blade.
Keep a skill saw with cement blade handy.
Have a jig saw with a Carbide-dust tipped blade (HD sells them).
We also hook up portable dust vac systems hooked up to the saws.
Use higher safety-level canister-filter type dust masks.
We prefer to use Stainless Steel Ring shanks and coil siding nailers.
We like to use these: (
http://www.bearclip.com/) and we also insert flashing squares behind every seam.
