Nailing Hardi board siding
I am getting a bunch of different opinions so lets add a few more. I know I need to use galvanized nails on Hardi board siding but do you use roofing or framing nails. And to add to it if you use framing do you use smooth or ringed nails. I like to use ringed nails but don`t know if they will tear up my Hardi board. Or does it really matter----Thank you
Siding nails are good. similar to roofing nails.
Rings are good too. Nails - Wood Framing • Siding nail (0.09" shank x 0.221" HD x 2" long) • 11ga. roofing nail (0.121" shank x 0.371" HD x 1.25" long) OSB minimum 7/16" • 11ga. roofing nail (0.121" shank x 0.371" HD x 1.75" long) • Ribbed Wafer-head or equivalent (No. 8 x 1 5/8" long x 0.375" HD). Instead of asking for advice and getting "different opinions" go to the Hardie website and you can get a PDF installation guide. They will tell you what nails to use, how and where to nail, etc. Any advice counter to that guide could void your manufacturer's warranty, so use it. Here: http://www.jameshardie.com/homeowner/helpSupport_instructions.shtml |
Oh and their best practices guide is very good, from what I've read of it.
It would be very good for someone who doesn't have a lot of experience installing siding. *hint hint* |
Thanks, the last link you provided was alot clearer then the link from the Hardi's main page. I read the requirments on Hardi's web page but have talked to local contractors and they all seem to have their own way to doing it. I am gonna stick to roofing nails for the lap siding as i had figured since they have a larger head. I mainly was wondering about the ringed nails that some contractors use, but I thought they would tear up the cement board going in. I have done vinyl siding in the past but have never done Hardi board.
Pay attention to the detail depending on what zone your in to the height that you keep the bottom of the siding off the steps, deck, roof and above window and door trim. Very important. Look at figure 2, 3, 4 and 5. http://www.jameshardie.com/pdf/insta...hingle-hz5.pdf |
Hot dipped galvanized 8d. Roofing nails? There's a reason that they are called roofing nails.
use stainless only,they are worth the added cost, and yes you can get roofing nails in stainless
Do it the way it is supposed to be done and you have a warranty. Do it the way it is not supposed to be done you have no warranty. It is your choice which way you want to go. Don't complain if it bites you in the ass later. |
I use Stainless Steel Ring Shank Roofing Nails on Hardi Lap.
If the product is supposed to last "almost forever", the nails should too. |
| All times are GMT -4. The time now is 05:24 AM. |
