Nailing Firring Strips - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 04:25 PM   #1
PPBART's Avatar
Rewards Points: 357
Nailing firring strips
I'm planning to cover our carport and front porch ceilings with vinyl, and I'm gonna be installing 1x3 firring strips over an area of about 500 sq ft. I've installed firring on several smaller jobs and just nailed them up by hand -- but with a job this size, I figured to rent a framing nail gun. However, the guy at Home Depot warned me against using framing nails, said they would split the firring strips, suggested instead using finish nails. Before I make a choice, what advice can I get from you guys? How would you recommend I go about attaching almost 500' of firring strips?
PPBART is offline   Reply With Quote
Old 09-28-2012, 04:29 PM   #2
Rewards Points: 14,306
I use 8D siding nails there ring shanked and about 2-1/2 long.
Finish nails have no rings and small heads, there going to just pull out.
Never take the advice from someone wearing an apron.
Old 09-28-2012, 06:14 PM   #3
Rewards Points: 2,212
I agree that finish nails are not a good idea.
I use a ring shank nailer. Used most often for underlayment installation.
mae-ling is offline   Reply With Quote
Old 09-28-2012, 07:00 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
yup thats what we do. for thin furring strips we just plug in our coil nailer. or use screws..
for furring strips that are only 1/8" splitting is inevitable no matter what size nail. instead i cut strips of cardboard
woodworkbykirk is online now   Reply With Quote
Old 09-28-2012, 07:21 PM   #5
Would the cardboard just crush?
Old 09-28-2012, 07:25 PM   #6
Where did the cardboard and 1/8 come in? O/P said 1X's
Old 09-28-2012, 07:32 PM   #7
PPBART's Avatar
Rewards Points: 357
Originally Posted by woodworkbykirk View Post
...for furring strips that are only 1/8" splitting is inevitable no matter what size nail. instead i cut strips of cardboard
As noted in OP, I'll be using 1x3 strips.
Old 09-28-2012, 07:56 PM   #8
just stating..
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
Attaching firring strips to a brick face Raketemensch Building & Construction 0 03-29-2010 03:21 PM
firring strips? fabian Plumbing 9 02-10-2009 09:00 AM
Recommended way to attach firring strips to Drylock wall? jbwaechter Building & Construction 1 04-29-2007 04:08 PM
