Nailing Cedar Shakes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 01:35 PM   #1
I have an 11 gauge roofing nailer. Are these nails too big for hand cut cedaor shakes?
McGinty is offline   Reply With Quote
Old 04-28-2012, 02:17 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
for shingles or shakes you should be using a siding coil nailer which shoots ring shank nails.. the same type of gun typically used for putting down underlay. for shakes they need to be faced nailed with finish nails in conjunction with the blind nailed ring shanks.. it keeps them from curling or cupping
woodworkbykirk is offline   Reply With Quote
Old 04-28-2012, 02:50 PM   #3
Rewards Points: 13,450
Hand or coil the nails should look like this.
http://www.wrcla.org/cedarspecs/installing/nails.asp
Old 04-28-2012, 08:30 PM   #4
Registered User
Rewards Points: 5,482
Your roofing gun won't work for wood shakes.
Nails or staples, per IRC; http://publicecodes.citation.com/ico...003_par010.htm
http://publicecodes.citation.com/ico...003_par011.htm
Gary
Old 04-28-2012, 08:43 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
http://www.cedarbureau.org/installat...al/page-05.asp
this is your go to for information on correct installations
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Gary in WA (04-29-2012)
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Celotex/Masonite behind Cedar Shakes shub Building & Construction 1 09-22-2011 07:01 PM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 07:51 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 05:22 PM
