Nailing Cedar Claps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 06:43 AM   #1
nailing cedar claps
just finished installing certainteed cedar impressions shakes.(vinyl).on my cape cod. i have an enclosed breezeway to finish and want to put up real wood. like look of cedar claps that will be painted grey. anybody got nailing info? been looking around and havent been lucky. not sure of where to put nails and what kind, thanks.
mazey is offline   Reply With Quote
Old 11-09-2011, 08:15 AM   #2
Rewards Points: 5,336
Easy to check the manufacturers website as to the nailing instructions of the siding you choose.
Ron
B. Franklin 1759
Old 11-09-2011, 10:37 AM   #3
its pieces of real cedar lap, no directions come with wood. lumber yard giving mix advice.
Old 11-09-2011, 10:48 AM   #4
kwikfishron's Avatar
Rewards Points: 84
You want to hit the studs in the wall.
Nail about 1 ” up from the bottom of the piece. You want the nail to be just above the overlap of the piece below. Don’t nail through both pieces.
Unlike vinyl the nails will be exposed. Use 7d ring shank “siding nails”, preferably stainless steel.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
BigJim (11-10-2011), woodworkbykirk (11-09-2011)
Old 11-09-2011, 12:30 PM   #5
got it, so the nail only goes into 1 piece, not the 1 it overlaps. but with the nail up that far will the edge start to curl up? or is it best to allow a little room for expansion. thanks
Old 11-09-2011, 01:31 PM   #6
47_47's Avatar
Rewards Points: 44
http://www.wrcla.org/installation_an...ng/default.htm
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
kwikfishron (11-09-2011)
Old 11-09-2011, 10:21 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
exactly as kwik fish stated.. the reason for using stainless steel nails is because they wont bleed like galvonized nails will.. the cedar reacts with galvanized nails.. when it does you get streaking on the siding
woodworkbykirk is online now   Reply With Quote
Old 11-09-2011, 10:57 PM   #8
Registered User
Rewards Points: 4,902
Depends on the coating, iron or steel stains happen when the coating is poor or missing at application:
Hot-dipped galvanized as per ASTM A 153, aluminum and stainless steel fasteners are all corrosion-resistant and all can be used to fasten Western Red Cedar. Other types of fasteners (including electroplated and mechanically galvanized) are not recommended. They can rust and disintegrate and react adversely with the natural preservative present in cedar resulting in stains and streaks. From: http://www.wrcla.org/pdf/WRCLA_Installing_Siding.pdf
Are you installing over exterior rigid foam board? Paper or plastic WRB?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
woodworkbykirk (11-10-2011)
New basebords and trim are white but all window frames are stained cedar? mibson Interior Decorating 0 01-22-2011 02:27 PM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 08:51 PM
cedar deck looks like crap silky Painting 16 05-02-2009 11:42 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
