Nailer Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 09:41 PM   #1
Rewards Points: 81
Nailer Needed
I have pretty much finished framing my basement! I have two places I'm not sure if I need to add nailers for the drywall. The areas in question are in yellow on these pictures. Do I need to add nailers in the yellow areas? How wide can this distance be before I need to add nailers?
OhioDon is offline   Reply With Quote
Old 12-05-2010, 09:55 PM   #2
To me, the question of nailers needed depends on fastener spacing. 6" spacing for dw screws tells me that if the unsupported distance is <3", you don't need a nailer. If it's between 3 and 6", I'd certainly consider the nailer. If it's more than 6", I'd say you definitely need one.
I'm no expert, so I'm just thinking out loud to try and see if I can come up with something that makes sense.
JH
Hohn is offline   Reply With Quote
Old 12-05-2010, 10:13 PM   #3
Registered User
Rewards Points: 5,204
7,11,12,16, or 24", take your pick. Fig. 3,4,and 5, read 4.9.1 here: http://gypsum.org/pdf/GA-216-2010.html
Remember to fire-stop...
Gary
Old 12-05-2010, 10:17 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 182
Omit my comment
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-06-2010, 10:43 AM   #5
Rewards Points: 5,336
That overhang will be supported by the wall sheetrock from below. I don't think you need nailers on either section.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (12-06-2010)
Old 12-06-2010, 11:30 AM   #6
Rewards Points: 1,558
Likely not; only issue may be when you tape the joint and you have some flex.
bob22 is offline   Reply With Quote
Old 12-06-2010, 11:45 AM   #7
Ron
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 08:58 AM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 02:16 PM
Which cordless nailer should I buy? Mike2181 Tools 8 09-23-2009 02:04 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 04:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 07:55 AM
