Nail In Top Plate Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 01:34 PM   #1
Nail in Top Plate Basement
When installing the top plate for an interior non load-bearing in a basement what size of nail should I use to nail the top plate into the blocking and joists? Is it 16d or some other size, because a 16d will stick out half an inch if I nail through the blocking. Also, when attaching the top plate to the joist or blocking do you nail in one nail at each location or do you have to put 2 side by side?
buildit45 is offline   Reply With Quote
Old 04-06-2012, 09:11 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Most guys put in a couple of 16d's right about where the stud is....if you go at a slight angle it's less likely you will hit the nails below. You want to avoid putting any nails between studs....you never know when your going to need to drill holes in the plate to run wires of plumbing....
I belive 10d in min....a 10d will not penetrate through the second (bottom) plate.
The Following User Says Thank You to ddawg16 For This Useful Post:
mae-ling (04-06-2012)
Old 04-06-2012, 09:12 PM   #3
firehawkmph's Avatar
Rewards Points: 1,922
3" nails work fine.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-06-2012, 11:19 PM   #4
Registered User
Rewards Points: 526
Between the studs nailing is fine if you didn't stack them...... If an exterior wall next to the concrete wall running with the joists, fire-stopping is required in addition to blocking. Any space behind any exterior wall should stop a wall fire from becoming a joist cavity (ceiling) fire. It could race down the joist space and surface in the back room above or even the attic, following any wiring/plumbing holes left unblocked. Sorry; if this doesn't apply, just be very safe when adding walls in basements....
Gary
Old 04-10-2012, 02:55 PM   #5
Thanks for the reply's, though I still need to know do you put one nail or two nails at each blocking and joist location?
Old 04-10-2012, 02:56 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
One is good,two is better.
sublime2 is offline   Reply With Quote
Tags
basement , blocking , joist , top plate
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Illustrated nailing schedule? cortell Building & Construction 6 11-29-2010 09:26 PM
Drain in basement floor has metal plate about 6" down 99miles Plumbing 8 09-29-2010 11:22 PM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 08:38 PM
Basement 2x2 furring strips, basement clutter, top plate not attached to floor joists touchsuhas Remodeling 5 12-26-2007 06:01 PM
