Nail Gun Spliting Wood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 06:30 PM   #1
Rewards Points: 99
Nail gun spliting wood
Still building my garden shed and its been nothing but a "one step forward and three steps back" project.
I know there is no cure for stupid but maybe some help here will work.
My pneumatic framing nailer keeps splitting the 2x4's half the time. Is the nail gun not set up right?
Am I using cheap wood? Wrong size nails? Not aiming or pulling the trigger right?
Thanks for any help.
kirwinjd is offline   Reply With Quote
Old 08-24-2013, 06:38 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
What is the pressure set at and where are you hitting the board.
Should not be splitting it if you are locating them right, sizing the fastener right, and not over driving them.
Old 08-24-2013, 06:39 PM   #3
DIY staff
Rewards Points: 7,174
You may have some brittle 2x4s----hemlock splits like that---does this happen when toe nailing or when nailing through the bottom plate into the end of the 2x4?
What size nails?
woodworkbykirk (08-24-2013)
Old 08-24-2013, 06:55 PM   #4
Rewards Points: 99
I'm probably doing all the above wrong. The Hitachi framing gun is a loaner by a friend. Any idea what the pressure should be?
Thank you.
Old 08-24-2013, 08:32 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
framing guns should be run at 110 psi.. some will argue this though.. i run them at 110 so im not having to finish the nails by hand, now mind you i also use quite a bit of engineered lumber which requires more pressure to sink air spikes
woodworkbykirk is offline   Reply With Quote
Old 08-24-2013, 08:41 PM   #6
Rewards Points: 12,852
What are you trying to do with it?
And as already asked what size nail are you trying to use.
Old 08-24-2013, 08:41 PM   #7
DIY Enthusiast
sublime2's Avatar
Thank you.
Shouldn't be any more then 90 psi.
sublime2 is offline   Reply With Quote
Old 08-24-2013, 09:04 PM   #8
Rewards Points: 99
Basic framing of a garden shed with 2x4's.
wood splits mostly within 3" of the end.
Using mostly 8d nails.
Thanks.
Old 08-24-2013, 09:14 PM   #9
If you build the walls laying down with 10 d nails though the tops and bottom plates there will be no splitting.
Your trying to nail at to steep an angle or to close to the bottom of the stud. Need two nails on one side and on more on the other side in the middle.
kirwinjd (08-24-2013)
Old 08-25-2013, 07:29 AM   #10
Rewards Points: 3,130
Though I'm an experienced DIYer and have a couple of smaller air nailers, the framing nailer scares the heck out of me. When we built our log home a couple of years ago, I did all the framing the old-fashioned way, with a hammer.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (08-25-2013)
Old 08-25-2013, 08:18 AM   #11
DIY staff
My wood shop teacher said this." A power tool is just a hand tool with malicious intent."
I have seen more injuries with a brad gun,than with a framer----the framer is obviously dangerous so people are careful.
The brad gun looks safe---but the nails fish hook frequently and stick the finger of the careless worker that holds the trim to close to the gun nose.---
Always be careful with any tool----Mike----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Gymschu (08-25-2013), ThatDaveGuy (08-29-2013)
Old 08-25-2013, 09:13 AM   #12
AHH, SPANS!!!
Rewards Points: 1,166
I keep the pressure at 120 for most of my air guns and adjust the nose piece on the guns accordingly. for toe nails if you set the pressure around 110 to 120 and max out the nail depth setting on the nose piece then toe nails should set just fine, if it splits stick it again and make it hold...
hand drive is offline   Reply With Quote
Old 08-25-2013, 07:27 PM   #13
framing guns should be run at 100.. other wise you'll be driving nails home all day with your hammer to finish off shiners
Old 08-25-2013, 07:45 PM   #14
Excellent advice for sure. I shot a finish nail side to side through the top of my thumb while building my house. Thing was, it didn't hurt. I pulled the nail out, and I didn't bleed. Now I don't even have a scar.
Old 08-25-2013, 08:07 PM   #15
DIY staff
I had a similar experience---no pain---pulled it out and finished the day-------
kirwinjd (08-26-2013)
Replacing Windows in home with LOTS of wood DomiFamily Building & Construction 0 05-14-2013 12:38 PM
wood paint for fireplace box pberm1962 Painting 3 05-02-2013 09:22 PM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 04:23 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
