Nail Bleeds On White Cedar Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 07:12 PM   #1
Nail bleeds on white cedar siding
My home is sided with unfinished white cedar board and batten. I would like to stain it (it is now 5 years old), but my builder used the wrong nails and the house is covered in black nail bleeds (streaks). Residing is not an option, nor is removing and replacing all the nails. Should I simply try to match the stain to the streaks (not my favourite option!), or are there alternatives?
I would appreciate any light you could shine on this topic. Thanks!
Baerg is offline   Reply With Quote
Old 05-26-2012, 07:32 PM   #2
Rewards Points: 636
i would post in painting. steel and cedar do not mix hope your contractor learned
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
Last edited by jaydevries; 05-26-2012 at 08:42 PM. Reason: kwikfishron corrected me
jaydevries is offline   Reply With Quote
Old 05-26-2012, 08:10 PM   #3
Rewards Points: 14,290
You may now be stuck with having to seal every nail with oil base primer and painting now instead of staining. If not the nails will just keep on rusting.
jaydevries (05-26-2012)
Old 05-26-2012, 08:26 PM   #4
kwikfishron's Avatar
Rewards Points: 996
Originally Posted by jaydevries View Post
galvanized and cedar do not mix
That's a new one on me.
Steel and Cedar don't mix. Hot dipped galvanized is fine with cedar if your not in a salt environment (on the Coast), electrostatic galvanized are worthless though.
I'd take the prime and paint a step further and countersink and fill the holes first, if the gun didn't already do the countersinking for ya.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (05-27-2012)
Old 05-26-2012, 08:37 PM   #5
If they knew it was going to be stained then stainless steel should have been used.
There also should not have been any exposted nails in the siding only the trim.
http://www.wrcla.org/cedarspecs/installing/nails.asp
Old 05-26-2012, 09:21 PM   #6
Rewards Points: 996
I can't think of any other siding detail that has more trim than B&B.
It sounds to me that it was all gun nailed, hopefully Baerg will post some pictures.
Removing vinyl siding from cedar mikegyver Carpentry 1 02-17-2011 07:47 PM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 07:36 AM
Need advice on painting new cedar siding epsaklas Painting 1 03-08-2010 05:20 PM
Need to restore faded cedar siding on ranch house Jimigunne Painting 1 02-23-2010 12:55 AM
Cedar siding: why can't I just let it weather? Ptron Building & Construction 4 02-19-2010 07:56 PM
