-   -   Mystery pipe (http://www.diychatroom.com/f19/mystery-pipe-176378/)
Dadof6 04-05-2013 01:51 PM
Mystery pipe
3 Attachment(s)
Hello all,
I have a mystery copper pipe coming up through the slab on the side of my house. I want to put storage sheds in this location but this pipe is in the way. I'd apprecate any input on wheter it is something obsolete (can I cut it off), should I plug it or do I consider rerouting it. It is appx 6-8 in above the concrete. It appears to be from the original construction of the house but the lab was poured around it later on (previous to me).
Thanks!
jagans 04-05-2013 02:01 PM
Im confused. Is this coming through the sidewall below what appears to be stucco or a slab on grade?
It looks like it may be a pressure relief pipe from your Hot water heater???
Dadof6 04-05-2013 02:36 PM
The pipe is coming up through a slab that has a slight slope to it. The photos are looking down. The house has a stucco exterior. In regards to the question of the hot water drain, this pipe is very distant from the hot water heater... I just checked, it is not the hot water drain.
the mystery continues...
HouseHelper 04-05-2013 03:07 PM
Any chance you have a buried heating oil tank in that area?
jagans 04-05-2013 04:45 PM
Blow air into the end and see if you can hear it in the basement anywhere.
Canarywood1 04-05-2013 08:13 PM
That's the condensate drain for the AC.
jbfan 04-05-2013 09:05 PM
Only if he has a pump.
Dadof6 04-05-2013 09:22 PM
Great suggestions! Unfortunately, we don't have an oil tank nor a basement and the AC condensation drain is on the otherside of the house... Also of note, there is nothing on the other side of the wall there that would contribute to the existence of the pipe... its the living room, no plumbing of any kind there. The kitchen (in aspect to the photos) is approximately 12 feet to the left, that is the only element in this area that has plumbing.
wkearney99 04-06-2013 09:47 AM
Wait, you don't don't have a tank "now" but might there have been one there in the past? Check with your neighbors to see what sort of heating they've got (or had in the past). See if any of the other houses built the same have a pipe like that in the same location.
Because if it was an oil tank that's no longer being used then you'd REALLY want to have it removed, or be SURE it's gone. Otherwise a leak (if it hasn't already) can get VERY expensive to clean up.
ddawg16 04-06-2013 10:06 AM
Is the pipe open?
Can you blow air into it?
It might be an air tube for a hidden compartment where the previous owner kept the kidnapped people.....if it smells....then maybe you have bodies underneath....
Jason34 04-06-2013 10:13 AM
Its most likely a pipe for something thats not being used anymore.
creeper 04-06-2013 10:23 AM
Thats right !
Dead people don't use air anymore
Windows on Wash 04-07-2013 08:32 AM
Doesn't look like a heating oil vent. More like condensate or other application.
hand drive 04-07-2013 09:05 AM
could have been a DIY water spigot that was in use before concrete was poured around it but abandoned now.
AndyGump 04-07-2013 10:20 AM
This is in California, no heating oil here.
Andy.
