Mysterious Metal In Masonry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 07:25 PM   #1
Mysterious metal in masonry
As I was repointing my chimney over the summer, I found two or three strange pieces of corrugated metal embedded in the mortar.
Click here for a closeup.
They're about four inches wide and don't appear to serve any purpose. They're well over a foot above the roof line so they can't be flashing and since they're isolated, they would be lousy flashing anyway.
The house was built in 1909. The chimney is river rock with portland cement mortar in the exterior over a brick interior built with lime mortar (common practice around here at the time).
I just pointed right over these strange things.
scowl is offline   Reply With Quote
Old 01-22-2009, 07:29 PM   #2
Brick ties? Were they connected to the inner block?
jerryh3 is offline   Reply With Quote
Old 01-22-2009, 07:29 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
If I remember correctly you are looking at whats called masonry straps. They are usually used by nailing them to a wall such as wood, or into the mud joint of cinderblock during construction. They then get bent down as the masons build up the brick wall. They bend them down into the bricks mud so they hold the brick to the wall. They could have used some in the chimney for stability and or strength. I can not tell by the pix. If I was there in person I could tell exactly why they installed them. Dont worry about them. They are ok.
USP45 is offline   Reply With Quote
Old 01-22-2009, 07:42 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
agreed.
Old 01-22-2009, 07:47 PM   #5
That makes sense. The interior of the chimney is brick while the exterior is river rock. These would help to tie the rock and the brick together.
I wasn't worried about them other than they had rusted a little and looked like they were intended to be protected with mortar. So I mortared over them.
I lived in England for a couple of months in the 90's and a big business there was replacing galvanized wall ties that had rusted after a century of holding brick facades to concrete blocks ("frieze blocks") in residential houses. After hearing those stories, I don't like the idea of any rusty metal in masonry.
Old 01-22-2009, 08:09 PM   #6
USP45's Avatar
Rewards Points: 150
Keep them covered with mortar. That helps
Old 01-22-2009, 09:25 PM   #7
Rewards Points: 1,232
They are there to hold the veneer AWAY from the backing, actually.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-22-2009, 11:48 PM   #8
As the ties rusted away, walls of brick started falling off houses and injuring people. It seems the failing ties were keeping the brick away from the rest of the structure too well.
Since thousands of houses had been built with galvanized ties, this became a national home owner crisis, much like leaking underground oils tanks were/are here.
Old 01-23-2009, 07:40 AM   #9
They are building houses every day with galvanized brick ties. It is the industry standard. They have increased the gauge though.
Old 01-23-2009, 11:06 AM   #10
In America that makes sense. Galvanized ties will probably last longer in many parts of our country compared to continuously damp Britain. Also brick is a small percentage of residential siding here while it's a majority of residential siding in Britain. They won't all fail at the same time here so it won't be a widespread crisis. It certainly won't get the press that LP siding and synthetic stucco failures have gotten.
Also, we don't expect things to last. If a brick wall starts falling apart after fifty years, big deal. Tear it down and build another. To the British, brick is forever and shouldn't fail like this since there are thousands of ancient brick buildings.
The article I read showed that at least in Britain, stainless steel ties don't increase the cost of construction all that much compared to the cost of the brick and the labor.
Old 01-23-2009, 05:09 PM   #11
Ancient brick buildings were built using a different type of construction. They are structural masonry construction, not masonry veneer structures. However, they were sometimes veneered with finished stone tied with various types of metal ties (lead or copper, but sometimes iron), and these have for the most part failed as well (and relatively quickly, too). Stainless Steel is usually a good choice, and is a small portion of the overall cost, although it is often 5 to 20 times as expensive as the equivalent galvanized tie, and has problems of it's own.
What type of metal to flash chimney and masonry wall? Max1119 Roofing/Siding 6 05-03-2008 05:58 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
