Old 05-17-2012, 10:53 AM   #1
My strange house
I have two nagging questions about this house I own, it was built in 1951 and it's Dutch Colonial style...
1. The ceiling height on every floor is 7'2". They're not drop ceilings, this is to the plaster that's on the joist. Anybody know why this would be?
2. The lath is drywall. I never imagined anyone would plaster over drywall. Isn't this why drywall was invented, to avoid using plaster?
Anyway, just two questions that have bugged me for years. Thanks
schatzi is offline   Reply With Quote
Old 05-17-2012, 12:25 PM   #2
MarginallyQualified
My strange house
Probably because that was the MINIMUM allowed by code.
hint: look for (beware of) other bare minimum standards of work.
The lath is drywall. Isn't this why drywall was invented, to avoid using plaster?
That is probably "rocklath". A very popular wall system then.
I have it at my house too.
TarheelTerp is online now   Reply With Quote
Old 05-17-2012, 01:12 PM   #3
joed's Avatar
My strange house
The drywall type lath was an intermediary stage between when they used wooden strips and just drywall. It was used in place of the wood as lath before someone figured out that you could put nice paper on it and use it without plaster.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 05-17-2012, 09:00 PM   #4
My strange house
I have this in my house also! Plaster and rock lath is superior to drywall as its many times stronger and limits the transmission of sound through out the house.
Dry wall was developed as a cost cutting method.
In my house, the outside walls were sheeted with rock lath that has an aluminum foil on the inside surface. This reflects radiant heat back into the building and forms a vapour barrier.
When I bought my house there was no insulation in the walls so I had cellulose blown into the cavities. (R13)
The heat saving with this combination is very economical.
The rock lath was manufactured in sheets 16" wide by 48" long and was generally installed horizontally.
Old 05-18-2012, 08:32 AM   #5
Custom User Title
My strange house
Wow, I'm glad I read this thread. I have always wondered what the heck kind of walls I had and could never figure it out. It looks like (2) sheets of 3/8" drywall on top of each other but the Rock Lath makes more sense. It sucks drilling into it since it is so hard and it ruins saw blades in a hurry.
no1hustler is offline   Reply With Quote
Old 05-18-2012, 08:43 AM   #6
My strange house
I use a masonry bit in an impact drill to drill it, reguler saw blades in like a sawsall will only go a few inches and be distroyed. I use a tile cutting bit in a Roto Zip. for bigger holes I use a diamond blade in a ciruler saw.
For round holes like for a can light Greelee and Remline sell a hole saw made just for this with Carbide cutting surface.
no1hustler (05-18-2012)
Old 05-18-2012, 09:33 AM   #7
Custom User Title
My strange house
Thanks for the tips Joe!
Old 05-19-2012, 10:04 AM   #8
My strange house
that's not what I have then. Must be regular gypsum. I can saw through it easy.
Old 05-19-2012, 12:37 PM   #9
My strange house
For a while some did plaster over drywall. I read about a year ago of a company that still does it.
mae-ling is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
