My Roof Is Sagging - Correct Course Of Correct Repair? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 03:16 PM   #1
My roof is sagging - Correct Course of Correct Repair?
My roof is sagging due to beams through out my attic sagging and cross beams bowing and pulling apart. This happened due to hurricane Ike.
I hired a contracting company to repair the attic and put on a new roof. I'm concerned because we agreed they would repair the attic and then put on the roof in case the decking and existing roof took more damage.
My question is, don't they need to use a hydraulic jack or another type to raise the sagging areas and then brace the area with a truss? I helped and watched this work done many years ago. I know we had to replace to roof afterwards.
young-jennifer is offline   Reply With Quote
Old 12-14-2008, 09:32 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
you can usually use other boards as a lever for positioning small beams etc,for really heavy stuff,you would use a jack
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 12-14-2008, 09:40 PM   #3
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Originally Posted by Ed the Roofer View Post
It may have been installed with the grain in the wrong direction.
Could you (or someone else) explain this.
Do you mean laying the sheathing horizontally or vertically ?
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 12-14-2008, 09:56 PM   #4
What Ed meant was the 8 ft. length should run a\opposite the direction of the rafters run(grain is the lines in the plywood)
usually a bow is from a rafter that wasn`t crowned properly during framing,meaning rafters are examined prior to rafter layout so the curve/crown faces up,all facing the right way means they settle along the same pattern,and roof looks good,one or two facing the wrong way-means those rafters are curing in opposite directions-hence the bow--plywood against the grain would have very poor strength,but will not necessarily show a bow/dip in the plane of the roof
Old 12-15-2008, 10:20 AM   #5
If it happened directly from a hurricane, my guess is it came from positive pressure causing the sheathing to deflect enough to push out the lateral bracing between the rafters/trusses. Thats a lot of force and I would of thought the other side would have blown off as negative pressure is usually higher. Sounds like the roof and sheathing needs to be removed in the affected area and try to realign the rafters/trusses or replace them, THEN put your sheathing and roof back on
ncgrogan is offline   Reply With Quote
Old 12-15-2008, 07:59 PM   #6
I agree with the last post. There must be some bad rafters if you can see a bow. Keep replacing until there is nothing crooked. If the sheathing was OSB and got wet then it's history.
losttool is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 10:00 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 04:16 PM
