-   -   My project (http://www.diychatroom.com/f19/my-project-170217/)
RWolff 01-26-2013 10:03 PM
My project
Facade restoration.
Here is a "before" picture of my building's facade,plain, boring, UGLY!!!!
It was previously a law firms offices, so they put this redwood siding in about 40 years ago I learned. I suppose it gave it a contemporary lawyerish look, but I just knew there had to be a brick facade under that garbage yearning to be free again.
It os easy to see how bad this looks next to two charming victorian and turn of the century buildings.
Once we closed on the building and I got the keys, the first thing I did was yank off a few of the boards to look underneath
http://i.imgur.com/mWrzG0q.jpg
http://i.imgur.com/cIURO4H.jpg
I found high quality hard brick, so I decided there and then, the rest of that redwood garbage was coming off!
Here it is half off, the facade doesn't seem tall, but I was amazed it took 3 sections of scaffold plus a 4th one I put up after this to reach the top which is about 23 feet up.
http://i.imgur.com/RVZAdg2.jpg
Once all that garbage was off, I needed to box in the parapet because they had extended the roofing over the parapet wall and had used the 2x6 rafters to hang the redwood facade from, it wasn't even really attached to the brick at all except at the very base.
Because the roof is PVC membrane and secured on the front edge with a drip strip and screws,I didn't want to disturb that, so I tapconned a 2x3 into the parapet stone, screwed up through the 2x3 into the rafters with 6" long deck screws to secure them down, then I screwed pressure treated boards in to form a box cornice.
The photo shows the cornice about half made. I primed and painted this after caulking it well.
http://i.imgur.com/i0cQtV2.jpg
Almost finished with the cornice, I may put a couple of fancy brackets appropriate to the style under it on both ends, but for the time being I needed to get this done quickly and the scaffold returned to work.
http://i.imgur.com/Sm07Hcw.jpg
After this, and before fall set in, I stopped at this point for the winter.
The darker green over the windows is temporary, there were signs there was a cornice there once, copper sheet along the wall there can be seen was cut all the way across, it was either copper flashing for it or the cornice was copper, I have plans to recreate an appropriate replacement, for now the bare wood needed to be primed and painted.
And in case anyone is wonder, YES, this was a 100% DIY project all done by myself, including setting up that scaffold and taking it back down again.
http://i.imgur.com/iLU2tg7.jpg
TheEplumber 01-26-2013 10:12 PM
199 Attachment(s)
I gotta say that that was ugly :jester:
But you did a great job and it's defiantly an improvement- nice job!
I bet the neighbors love you now
RWolff 01-26-2013 10:46 PM
So now we come to the entrance door! Man, what a sorry sack of garbage that door and display windows are, the door looks like one you'd have on a drug store or licquor store, I hate it I hate it I hate it, did I mention how much I hate that door?
I thought about this a lot, and this is somewhat close to what I have planned, but not as ornate/Victorian:
http://i.imgur.com/841DeAa.jpg
Towards that end, I decided I wanted to have two doors and to straighten out the 2 angled windows, I built the 2 doors, here's the frame of one of them to start with. It is laminated poplar about 1-5/8" thick, mortice and tenon joints.The top will have bevelled glass, the bottom openings were going to be panels but now I'm thinking glass there would better match the facade style due to the 6 small square windows over the display windows.
http://i.imgur.com/GalVBqV.jpg
Going back inside, this is the rear area "before", dark GREEN paint on the walls! There was a partition wall I removed where I was standing with the camera, so it was a dark hovel before I did that! I also discovered the boarded up window in the back upstairs was not facing a brick wall as I thought, but could be uncovered, they had instaleld the same redwood garbage on the rear as the facade had and covered the window over!
A new double hung vinyle window, argon etc replaced the old one and it lets a lot of light in from the West now.
This area will be a work and class area, the front half is for the gallery space.
http://i.imgur.com/bgM8jzp.jpg
Another view after the window was installed and painting the walls. I built a pair of oak railings with newel posts (posts not shown) where the partition wall was,it was the perfect diving location as the rear area has new linoleum flooring and I decided to keep that. The divider is just perfect for the purpose of visually separating the two areas but keeping maximum sunlight going to the rear from the front windows.
In the foreground is plywood, the original wood floor has 2 layers of linoleum, likely asbestos tile, lots of holes for outlets, and I felt it was just beyond dealing with trying to restore it.
So 5/8" CDX screwed down for a subfloor for planned oak parque covers 20x42 feet.
http://i.imgur.com/YHjWnMM.jpg
The 2 posts installed
http://i.imgur.com/If1UjZb.jpg
Some views looking to the front "before"
http://i.imgur.com/rrgHvAM.jpg
http://i.imgur.com/scOVzFj.jpg
And towards the rear when the partition was still there, real raw space!
http://i.imgur.com/j0yPDfe.jpg
Part of the upstairs mezzanine with the original window uncovered, letting light in there for the first time in 4o years.
http://i.imgur.com/n2m1w7s.jpg
After painting the entire ceiling with oil paint, and the walls with 2 coats of latex paint, I was able to start mounting some of my work on the walls.
I found a couple of 1910 period looking hanging lamps for the front area to start with, one can be seen, it fits well!
I gave the cornice a contrasting color, the wall is not quite as yellow as the photo implies, the color is a bit off.
http://i.imgur.com/XzUGlxF.jpg
I think that's it for now, I had hoped to get the oak prefinished parquet tiles at Menards but I learned they no longer carry it! WHat a headache because I was counting on getting that material as it's always been around $1 a sq ft or so and it's perfect for this space, now I'm finding parque sold elsewhere is either expensive cherry, mahogany, or it's around $3.99 or $4.99 a sq ft.
I hate carpeting but I looked at some for temporary for 20x25 of this area to start with, and I found some for under $1 a sq ft, but they wanted $3.79 a sq ft to install it!!!
I need about 900 sq ft, so finding a close-out of 900 sq ft or 900 left over tiles on Ebay cheap is not likely!
I guess the flooring is going to be last on the to do list for now.
Randall
fltdek 01-26-2013 10:48 PM
Nice job! Love the original brick. Looks very nice.
