Was My Local Lumber Yard Being Straight With Me? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2008, 10:15 PM   #1
Was my local lumber yard being straight with me?
I'm renovating my existing garage into living space and to do this I'm framing a floor which will bear on the existing foundation walls. To match the existing framing the new joists must be 2x8 and span 13'. I had planned on doing this with #1 grade lumber 12" O.C. but when I went to the yard to get an estimate done I was told they couldn't get #1 in anything less than 28' lengths and 180 piece lots. After I left I called another local yard and they said more or less the same thing.
So, is this really true? I have no reason to not believe them but I'm just finding it hard to believe you can't get #1 grade in 14'-16' lengths. I'm in MA, btw.
I'm currently planning to go with a beam down the center to split the span and use #2 but it sure would be easier to just do it with a single clear span.
RolandOG is offline   Reply With Quote
Old 05-27-2008, 10:40 PM   #2
remodeling pro
Evidently that is what is available from their supplier. I have never heard of only being able to get 28' lengths, but it is common for them to have to order quantities in what ever is the standard bundling units for an item. Have you considered using manufactured I beams, They are cut to specified lengths when ordered, and available in depths to match most dimension lumber.
troubleseeker is offline   Reply With Quote
Old 05-27-2008, 10:53 PM   #3
I was under the impression that you can't get I-beams in 7 1/4 depths. I didn't see anything on either the GP or Boise site. Maybe I missed it?
It being their supplier makes sense. Maybe I'll call a few more yards. I had hoped to use these guys because I heard good things about them.
Old 05-27-2008, 11:46 PM   #4
Registered User
Termite's Avatar
Most yards won't stock #1 material. When you buy it, you're buying the quantity that they bring in, which is full units.
As for the 28' length, that is strange.
I doubt you'll find anyone that stocks #1.
In the long run, I think it is going to be a lot cheaper to spend the extra money on a beam and use #2 material.
Old 05-28-2008, 09:13 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
I can't imagine what #1 2x8s must cost. Louisiana-Pacific makes LVLs to match 2x8. Probably cheaper than #1 softwood. Likely to be stronger too. If I could get away from the beam, I would. It's not just the beam, it's the posts, pads to rest the posts on, labor to assemble all of the above, etc. Especially since you're not very far off of the span table for # 2.
http://www.lpcorp.com/lvl/products/p...formation.aspx
Maybe Termite can check the official span tables. It seems like 2x8 northern fir on 12" centers should span the 13 feet you need. What does the book say?
Old 05-28-2008, 09:52 AM   #6
Registered User
Termite's Avatar
Certainly! (now that I have my book with me)
#2 Douglas Fir 2x8's will go 14'-2" @ 12"oc @ 40psf live/10psf dead L/360.
#2 Hem-Fir will go 13'-2"
Those are maximum spans of course, from the 2003 IRC.
Old 05-28-2008, 02:00 PM   #7
I have my structural engineer looking at the drawings now and he said he had some ideas for simplifying the layout. I'll wait to hear his ideas before making a final decision on beam vs. LVL's or #2 DF.
Thanks for the replies.
Perfectly straight line Casey Flooring 13 04-05-2011 11:18 PM
Dry lumber from HomeDepot HandyPete General DIY Discussions 17 03-25-2011 01:50 PM
My yard is ugly and I don't know an easy way to fix it. keyser soze Landscaping & Lawn Care 22 07-05-2008 03:43 PM
Straight Framing Lumber BigJimmy Building & Construction 10 12-04-2007 10:23 AM
Framing lumber very hard?? handyflyer Remodeling 2 04-15-2007 11:44 PM
