Old 04-15-2013, 09:57 AM   #1
Do it right.
My diagonal measurements say i'm square, but side to side disagree.
I had a concrete slab poured and am now laying one course of cinder block to get the walls off the ground.
I layed out blocks at the four corners and using the 3,4,5 formula figured out my diagonals need to measure 26' 11" which they do. However when I measure side to side I have one side that is 1/2" short and the opposite side is a 1/4" too long.
Of course if I adjust the block to correct those measurements it throws the diagonal measurements out of square. My question is, which measurement is the correct one? I'm assuming the diagonals. Or am I doing something incorrect?
SubSailor is offline   Reply With Quote
Old 04-15-2013, 10:03 AM   #2
You know rectangles have right angles also. Is your slab a rectangle or square?
hammerlane is offline   Reply With Quote
Old 04-15-2013, 10:24 AM   #3
Do it right.
rectangle 20x18
Old 04-15-2013, 10:33 AM   #4
Accuracy isn't too much concern in the manufacturer of blocks so I suggest measuring outside to outside or inside to inside for both dimensions if you aren't.
Fairview is offline   Reply With Quote
Old 04-15-2013, 10:35 AM   #5
By the way, if you are off by 1/2" or less you are fine.
framer52 is offline   Reply With Quote
Old 04-15-2013, 10:35 AM   #6
Maryland
Did you use 3,4,5 to confirm that your four corners are square? If all four corners are square and your footprint measures 18'x20', your diagonal measurement will be correct at just shy of 26'11".
Pittsville is offline   Reply With Quote
Old 04-15-2013, 11:17 AM   #7
Do it right.
I haven't set any block yet, I just set one block on each corner and adjusted until my diagonals were the same. Then I planned to run string off those corner blocks as a guide.
So i'm good as long as my diagonals are measuring correctly?
Old 04-15-2013, 01:13 PM   #8
sdsester's Avatar
Just a silly idea but why not use a framing square on this project?
sdsester is online now   Reply With Quote
Old 04-15-2013, 01:29 PM   #9
joed's Avatar
Measuring diagonals only makes a square IF THE OPPOSITE SIDES ARE THE SAME LENGTH. So make your sides the same length and then measure the diagonals for square.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
concretemasonry (04-15-2013)
Old 04-15-2013, 08:19 PM   #10
Do it right.
Problem solved.
I should have said I used pythagorean theorem instead of 3, 4, 5
Old 04-16-2013, 11:01 AM   #11
firehawkmph's Avatar
Originally Posted by SubSailor View Post
Problem solved.
In this case, same thing. A squared + B squared = C squared.
3 x 3 + 4 x 4 = 5 x5
I think thats where the 345 triangle came from.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-16-2013, 02:28 PM   #12
Increasing to 6 - 8 - 10 ft. will give you a little more accuracy on a building the size of yours and on larger parcels 60 - 80 - 100 .
The Following User Says Thank You to Fairview For This Useful Post:
firehawkmph (04-16-2013)
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 11:02 AM
Refinishing square cut side of 2x6 T&G for flooring cowbore Flooring 1 11-24-2008 02:13 PM
Poor Attic Ventilation Mechanically Challenged Roofing 15 10-23-2008 10:05 PM
Powered Attic Fan question spup345 Roofing 9 06-30-2008 09:10 PM
roof venting via the soffit darren Roofing 8 04-13-2008 10:29 PM
