My Corners Are Cracking When Hanging Drywall In The Ceiling, Why? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2007, 08:39 PM   #16
yummy mummy's Avatar
Rewards Points: 1,016
I would need to rent the lift for 2 weeks because I don't have the time to do it continuously. So this is why I am doing it by cutting the pieces.
I'm good with cutting the pieces.
It will take me forever but I have forever
yummy mummy is offline   Reply With Quote
Old 12-22-2007, 12:09 PM   #17
Rewards Points: 150
Originally Posted by yummy mummy View Post
Thanks K. But can I just use regular mud to fill in the cracks, and do I really have to clean it out.
Can't I just leave it the way it is, and then try to fix it with mud?
Thanks for your advice.
No you cannot do it with regular mud. It shrinks too much, cracks and takes too long to dry. But a bag of hot mud, mix in a 1 gallon bucket, clean bucket immediately with brush and sponge while it is still super easy to do so. Pre-fill the gaps and cleaned out break outs and then you will find the rest of the job is much easier.
It is also, NOT "just as good" to make the many patches. You have a much higher probability of a crappy looking job and cracking down the road. Much better to span with full sheets.
If you haven't already addressed the stud, what is going on on the backside and will that be a future problem? If not, just rip a piece of plywood and shim it out.
kgphoto is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 07:46 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
