My Breezeway And Garage Have 2x4 Rafters :( - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 08:18 PM   #1
Rewards Points: 93
My breezeway and garage have 2x4 rafters :(
Guys, house was built in the 50's , the rest of the house is 2x6 construction but for some unknown reason the breezeway and garage is 2x4 24 ioc!! I am converting my breezeway to a kitchen. the entire room is gutted down the beams. What can I do to the rafters to make them stronger before closing up the ceiling?? As of now there are no structural issues and sagging but it bothers the hell out of me! the sheathing is 3/4 in pine t/g
thanks guys!!!
Gnfanatic is offline   Reply With Quote
Old 10-08-2012, 08:28 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
Are they 2x4 trusses with metal strap plates at the intersect points?
hand drive is offline   Reply With Quote
Old 10-08-2012, 08:41 PM   #3
Rewards Points: 93
no sir, just some nails
Old 10-08-2012, 09:10 PM   #4
Rewards Points: 432
thanks guys!!!
I find it amusing and sad at the same time your breezeway and garage has stood just fine for 60 years and houses built today, with all the supposed technology of vapor barriers, venting, yada, yada, yada, won't live to see that ripe old age.
I say leave it alone so today's warping, twisting, bowing, cupping lumber won't contaminate yesterday's real lumber.
Old 10-08-2012, 09:15 PM   #5
Rewards Points: 93
yeah it is pretty damn incredible I have to admit. Simple yet it works, 3 10 d nails at each end, no straps not thing. I was thinking of adding a 2x4 strongback going across just to help out and make me feel better.
Old 10-08-2012, 10:12 PM   #6
AHH, SPANS!!!
How long are the rafters and the width across the room, wall to wall where the rafters sit? What size is the ridge board? Thanks
Old 10-08-2012, 10:22 PM   #7
DIY or die !
Rewards Points: 77
how long is is the run ?
lewisthepilgrim is offline   Reply With Quote
Old 10-08-2012, 11:18 PM   #8
Rewards Points: 93
I dont have the all the info for you right now. the ridge is amazingly 2x4 as well! the room is roughly a 10 x 10 room. I do not know how long the rafters are at the moment. it is a small roof , I will have the length tomorrow. I am thinking roughly 6-7 ft in length
Old 10-09-2012, 01:58 AM   #9
Registered User
Rewards Points: 4,914
The 2x4's may work for their span. http://publicecodes.cyberregs.com/ic...?bu2=undefined
Depends on any snow load, etc. that the Building Inspector could call you on. Converting a breezeway to a kitchen (living space) will require a permit, if used in your area. That way the structural safety, energy (insulation/air-sealing), and fire codes (including electrical) will give you minimum code protection to keep your family safe, and satisfy your H.O. Insurance carrier if ever a claim or when you sell the house.
Gary
Old 10-09-2012, 09:52 AM   #10
Rewards Points: 93
town is aware of conversion. I am filing for permits as well, I am doing it the right way . I will let you guys know about the rafter lengths.
thanks guys!
The Following User Says Thank You to Gnfanatic For This Useful Post:
Gary in WA (10-10-2012)
Old 10-09-2012, 10:13 AM   #11
DIY or die !
Rewards Points: 77
those are probably REAL 2x4s
Old 10-12-2012, 10:06 AM   #12
Rewards Points: 93
Here you go guys. Any comments on how can make this stronger is appreciated. Again, NO structural issues at all. I just dont care for the 2x4's and how the ridge just ends with no support under it???
the rafters are 5' 5" long.
[/IMG]
Old 10-12-2012, 10:07 AM   #13
Rewards Points: 93
oops
My breezeway and garage have 2x4 rafters :(-cake-001-small-.jpg   My breezeway and garage have 2x4 rafters :(-cake-002-small-.jpg   My breezeway and garage have 2x4 rafters :(-cake-004-small-.jpg
Old 10-12-2012, 12:42 PM   #14
DIY or die !
Rewards Points: 77
Add a simple support post on either end of the ridge. You could also add another 2x in between each current rafter, or just sister them. Honestly its not really a big deal. If it has held up this long with NO problems....but if it will make you sleep better
Old 10-13-2012, 02:27 PM   #15
Registered User
The ridge board ties the rafters together, pp12; http://www.awc.org/helpoutreach/ecou...seV09-2007.pdf
Rafters can be butted together, or gusseted, or fastened to a ridge board, per code.
Your location may or may not require collar ties, per code; http://www.awc.org/helpoutreach/ecou...seV09-2007.pdf
Yet collar ties may be removed, depending on where you live; http://www.finehomebuilding.com/how-...llar-ties.aspx
The rafter/c.joist connection is most important, last chart at bottom; http://publicecodes.cyberregs.com/ic...002_par023.htm
Page 179, add some 2x4 members between rafter/c.j. to make a “truss” system, if still worried about strength; http://books.google.com/books?id=bwt...page&q&f=false
Gary
Breezeway as a playroom Loveski Remodeling 2 04-02-2012 06:42 PM
Heating garage shop secutanudu HVAC 33 12-18-2011 07:51 AM
Garage and breezeway footers Npc5629 Building & Construction 2 07-27-2011 12:32 PM
Garage sub panel DoctorWho Electrical 13 06-29-2011 01:29 AM
Building an attached garage BowDown Building & Construction 1 05-20-2009 03:21 PM
