My Add-on Room In The Back Has 2x4 Ceiling Rafters! - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 11:16 AM   #31
Originally Posted by Daniel Holzman View Post
I suggest you take a breath and go back to the fundamentals. This roof has apparently been there for 50 years, so clearly it is strong enough to survive. Before you go "repairing" it, consider the simple question, if it is so grossly underbuilt, why is it still there? There is a lot of strength in old growth wood that is not reflected in current codes, which generally assume you will be using relatively low quality, currently available lumber, so this roof may be built with stronger lumber.
Second, the only significant vertical load on a roof comes from snow and ice, and the occasional impact from a falling tree. I exclude tornadoes and other serious wind events, those loads are complex, and are generally not considered vertical loads. So here is a possible option. The next time you get some snow on the roof, hire a local unemployed person to shovel off your roof. You can do this with a snow rake without even getting on the roof. That should extend the life of your roof through many more winters, at least until the roofing fails, then you get that replaced.
Since you lack the funds to properly frame the project, but clearing snow is relatively low cost, at least consider that option, and leave the roof as is until you can afford to upgrade.
Thanks, that makes a lot of sense. And I definitely try to clear snow off the roof whenever it begins to accumulate (originally a Vermonter so well versed in snow ). And yes, the question of why it's still there keeps coming back up. I will definitely have to consider my options carefully here.
OffToAShakyStar is offline   Reply With Quote
Old 10-10-2011, 11:21 AM   #32
kwikfishron's Avatar
Rewards Points: 1,016
Originally Posted by OffToAShakyStar View Post
Thanks, I more meant what would be the basic steps of doing that rebuilding. I assume I would cut the roof open where I would be attaching and tie into the roof rafters on the main house?
Thatís the whole point in having plans drawn up. The plans will answer all of those questions based on local code. For a few hundred bucks you will have the picture of exactly what needs to be done.
Your new roof more than likely can be built on top of the main roof but I have no real idea. Thatís why you need a local pro to do an on site assessment.
Once you have the plans in hand then you have real world numbers to work with to price out and budget for.
kwikfishron is online now   Reply With Quote
Vaulted ceiling crown molding with adjacent room cmcfalls2 Carpentry 4 10-13-2011 10:38 AM
how to build toy shelf near ceiling of kids room Kimmoski Carpentry 2 06-22-2011 07:22 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
