Musty Odor Behind Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 12:37 PM   #1
Angry
Musty odor behind drywall
I live in s florida and our house was built in 2003. The outside of the house was pressure cleaned and painted in 2007. This caused a mold problem on the family room wall as a result of the water from the pressure cleaning coming in through an exterior light fixture on our patio. The mold problem was resolved by mold specialists in 2008, however; as soon as the new drywall was installed there was a must odor coming the from electrical recepticle and fromt he door leading to the patio. We have removed the pavers from the patio because it was damp constantly as they were set in sand over concrete. The patio faces north and doesn't receive any sunlight so the sand was constantly damp underneath the pavers. To this date we have had numerous mold specialists and GCs out here and no one can find the cause for the musty odor, which we still have. We are at our wits end trying to resolve this problem. We need help as this smell is bothering my allergies.
admin20 is offline   Reply With Quote
Old 10-04-2010, 08:59 AM   #2
Rewards Points: 5,336
Was the wood sheathing allowed to dry before the new sheetrock was installed? If so, how was it determined it was dry? Was the siding removed on the exterior to allow the sheathing to dry? Is the receptacle in the area of he replaced sheetrock?
Have you removed the molding around the patio door to check for mold?
Was the wall insulated prior to the new sheetrock installation?
It sounds like the wall still has moisture trapped within.
Ron
Tags
musty odor behind drywall
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
