Mudding The Screws? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 09:37 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Mudding the screws?
Do I mud the screws that will be covered by tape at the seams, separately or are they just covered when I do the taping?
Also, do you leave 1" when drywalling the walls at the bottom?
One more question, do you install trim first and them tiles or the other way around.
And because I plan on putting tiles, do I do wood trim or cut tiles and put them all around?
Thanks......
yummy mummy is offline   Reply With Quote
Old 01-28-2008, 11:02 PM   #2
Rewards Points: 5,336
The screws are mudded when the tape is applied.
I usually leave 1/2" so I have a suface to screw into.
Install the trim first so you can install the tiles to a finished edge.
Ron
Old 01-29-2008, 05:52 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by yummy mummy View Post
Do I mud the screws that will be covered by tape at the seams, separately or are they just covered when I do the taping?......
No, the subsequent coats of compound will cover them.
Also, do you leave 1" when drywalling the walls at the bottom?......
We usually install the screws approximately 2" above the flooring, for ease of installing the screws. The thickness of your sub floor, finished flooring and baseboard will cover alot of the lower area of sheetrock.
One more question, do you install trim first and them tiles or the other way around. ......
It can be done both ways. We have done them both ways. The last bathroom we tiled, the owner wanted the Baseboard installed after the tile flooring. In general, most feel it looks better if the trim-work is installed prior to the tile. I feel, and have seen, that it can look good either way. See examples below.
And because I plan on putting tiles, do I do wood trim or cut tiles and put them all around? Thanks......
Same answer as above...
Examples of tile work first, with baseboard installed after:
- Build Well -
Old 01-29-2008, 08:44 AM   #4
Ron
Thanks Ron.
Old 01-29-2008, 08:45 AM   #5
Thanks Atlantic!
Also, thanks for posting the pics for me to see.
(You're wonderful)
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 01:31 PM
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 10:27 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
