Mudding A Arched Doorway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2008, 04:02 PM   #1
Livens's Avatar
Mudding a Arched Doorway
Hi,
This is my first time at this site, looks like a nice place to get help
I am finishing my basement and just got all of the drywall hung. I have drywalled a small room before so I had a little experience from before. But this time around my wife threw a curve ball at me, she wanted a curved doorway... her sister has one so she needs one too.
Here is where I am stuck... what type of corner bead should I use for the curved part? I have seen online flexible corner bead that has cuts every 1/2" or so. Can I just cut the slits myself, or is there something else special about it?
Thanks,
Jeremy
Livens is offline   Reply With Quote
Old 03-12-2008, 04:26 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Livens View Post
Hi,
Hi and welcome to the site.
That is the kind that you need.
No, that is not the same. If you attempt to do something like that, you will end up with just a lot of short straight edges.
The factory made flexible corner bead will create a smooth, clean, curve.
- Build Well -
Old 03-13-2008, 06:05 PM   #3
Rewards Points: 150
Or buy an easy arch.
kgphoto is offline   Reply With Quote
Old 03-14-2008, 04:11 PM   #4
Livens's Avatar
Thanks for the replies.
Flex bead it is! Now to find a local supplier...
As for easy-arch, NOW you tell me! I had actually searched for pre-fab arches, but had only seen the $150 types and assumed they would all be expensive. If I every have to make another arch I may go that route.
Thanks again
Jeremy
Old 03-14-2008, 04:25 PM   #5
Rewards Points: 150
Online supplier would be your best bet. You can get a roll of Trim Tex arch bead from All Wall or Warehouse Bay.
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 12:01 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 04:52 PM
arched opening ITE Remodeling 5 12-09-2005 06:14 PM
constructing a hidden doorway bubblehd Building & Construction 1 10-15-2005 03:13 AM
