Moving Wall Parallel To Joists - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 06:42 PM   #16
Rewards Points: 115
Yeah, that does sound like the safest approach. I'm assuming that means that I must remove the 2x6 that is already on that side? No way to attach to it that wouldn't weaken that span, right?
Ugh. I'd hate to have to remove it as I've already installed blocking.
Didymus21 is offline   Reply With Quote
Old 10-06-2012, 07:50 AM   #17
AHH, SPANS!!!
Rewards Points: 1,166
it looks like you spliced both sides, that looks great and will probably hold the joist up...maybe no need to do anything else.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Didymus21 (10-06-2012)
Old 10-06-2012, 01:01 PM   #18
Rewards Points: 115
That is great to hear! Especially great to confirm this joist is simply holding up drywall for the ceiling...
Thanks for all your help.
The Following User Says Thank You to Didymus21 For This Useful Post:
mae-ling (10-06-2012)
Load bearing beam that runs parallel with joists and supports 2nd floor above? Croitor Building & Construction 14 08-14-2015 11:56 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 12:59 PM
