Moving Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 03:09 PM   #1
Moving wall
Need to move load bearing wall 2ft in kit.approx 10ft long.
170426225 is offline   Reply With Quote
Old 08-06-2012, 03:37 PM   #2
Rewards Points: 502
So what?
tony.g is offline   Reply With Quote
Old 08-06-2012, 03:51 PM   #3
Don't now if it will effect integrity of structure
Old 08-06-2012, 04:18 PM   #4
Rewards Points: 502
There are probably too many unknowns for anyone here to give a definitive answer.
For example; is the wall supporting a floor or wall above? Is it built up to the underside of roof trusses? single or double storey house? Is it a stiffening wall (that is, a wall intended to brace the structure against wind- and seismic forces, even if it doesn't appear to carry anything above).
You really need someone such as an SE to actually look at the situation so that they can give you an informed opinion.
The Following User Says Thank You to tony.g For This Useful Post:
mae-ling (08-06-2012)
Old 08-06-2012, 05:15 PM   #5
Haverhill Trade 1965
I would ask your building inspector. One because they love to be consulted first, and two they may know a good reasonable engineer. Either way please them and you are way ahead to start.
Duckweather is offline   Reply With Quote
The Following 2 Users Say Thank You to Duckweather For This Useful Post:
concretemasonry (08-07-2012), tony.g (08-06-2012)
Old 08-06-2012, 05:56 PM   #6
Framing Contractor
Rewards Points: 112
Even a reputable contractor should be able to give you good advice. Most of the time, we can tell just by looking if it will be relatively easy or not. It will be even more expensive and possibly dangerous if you attempt to move it first without the proper knowledge.
sixeightten is offline   Reply With Quote
Old 08-06-2012, 06:19 PM   #7
kwikfishron's Avatar
Rewards Points: 178
Agreed...it isn't rocket science, framing 102 maybe.
The notion that an SE should always be the first call kinda peeves me about this place.
kwikfishron is online now   Reply With Quote
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
12penny (08-06-2012), mae-ling (08-06-2012), Pittsville (08-06-2012)
Old 08-06-2012, 10:16 PM   #8
Engineers degrees come with a size 27 hat you think?
Old 08-07-2012, 04:18 AM   #9
Rewards Points: 502
I can see your argument to a point, but how does the OP know if a contractor is reputable?
If some are short of work, they may just take chances and assume it will be OK moving it.
This is a DIY site and other posters have criticized anyone who says "get an SE in". However, whilst many of these jobs are DIY-able in terms of labour and getting materials in, sometimes it needs a qualified person to size members/specify fixings. A balance has to be struck.
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Moving a doorway in an exterior brick wall GeauxCajuns82 Building & Construction 6 01-05-2011 06:16 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
