Moving A Tie Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 06:19 AM   #1
Moving a tie beam
Hi
I understand and know why and what a tie beam does in my loft.
I have a rather big loft with plenty of space in which I have constructed a hobby room. Unfortunately the tie beam is at a height from the floor of about 3’, which is becoming a real pain to duck under every time. Will I be able to replace it a further 2' up in the same location with taller upright supports. Or would this weaken the support it offers?
In addition, as I have constructed my hobby room I have obviously built a ceiling within my room by adding beams from roof vertical struts across the loft that look like mini tie beams.
I will take some photo’s to add later if this will help to explain my problem.
DMeikle is offline   Reply With Quote
Old 01-02-2009, 07:13 AM   #2
Rewards Points: 5,334
Photos are good.
Ron
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
