Moving Studs On Load Bearing Wall For HVAC? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 10:38 PM   #1
Moving studs on load bearing wall for HVAC?
Hi guys and gals,
Im reworking an old house and trying to get another heat supply to the second floor. House is stucco so the there's basically firring strips on the exterior walls and this is just about the only spot to locate a supply. Based on the joists location I dont have much room to work with. I need to move one stud over about 2.5 inches to give me enough room for a supply. Take a look at the picture and let me know if this is feasible or if there are other alternatives. Thanks a bunch.
grouse is offline   Reply With Quote
Old 08-20-2009, 02:16 PM   #2
Registered User
Rewards Points: 526
So there are no interior walls..... Cutting an outside wall-- lose the structural integrity for shear flow, seismic flow, wind shear, lateral shear, etc. Loose most of the heat to the outside before it gets where you want it. I would look hard for another route.
Be safe, G
Remove section of load bearing wall MrD Building & Construction 1 07-14-2009 10:44 AM
windows in a load bearing wall bvpeterson Building & Construction 2 04-27-2009 07:01 PM
Load bearing wall or not? tv4184 Building & Construction 19 01-04-2009 01:12 AM
Moving a bearing wall towers22 Building & Construction 2 04-04-2007 10:04 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
