Looking for input to see if there is anything more I might need to do as I try to move a stud in a load bearing wall.
Shown below is an image of a corner of an unfinished basement wall. To orient yourself, realize that blue speck on the left side is the back side of an electrical box holding a switch for the outside of the left and wall. The far side of the wall already has plywood sheeting.
A new HVAC trunk is going to come through the facing wall pictured. Based on various height requirements, the new trunk must be 17" wide and located at the top of the wall.
Relative to the triple stud shown, what I want to do is double up the 2nd stud (on the outside) and chop off the top of the 1st stud. Doing so will given me a 17-1/2" space between the double stud and the triple stud.
What you can't see in the picture is the following:
1. The triple stud forms the support point for the corner of two walls upstairs, a kitchen/living room wall to the right of the triple stud, and a hallway is open on the left of the triple stud.
2. The bottom 2x4 of the double top plate has a joint centered over the 2nd stud (the one not moving).
