Moving My Fireplace In A Remodel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 09:45 PM   #1
Question
Moving my fireplace in a remodel
I want to move my 3 sided fireplace from the middle of my family room and bring it off the wall. I live in a town home and the wall it would come off is a common wall. Is this possible or would the building codes prevent me from putting a fireplace on a common wall??
The Drywall Guy is offline   Reply With Quote
Old 05-30-2011, 09:56 PM   #2
Full time DIY
Where are you? Update your profile via the User CP or put the info in post... Code is different everywhere!
G-Mo is offline   Reply With Quote
Old 05-30-2011, 10:03 PM   #3
Im sure that would help thanks for the input.I live in Denver Colorado. Its a 6 unit bldg.
Old 05-30-2011, 10:51 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Giving more information (as well as pics) might help. For starters, what kind of fireplace? Wood, gas, propane, electric?
Old 05-30-2011, 10:59 PM   #5
Im new to chat rooms so it might take a bit to get this down, thanks for the help. I can post some pics tomorrow. Its an exisitng gas 3 sided fireplace. The builder put it as the divider for the family room and dinning room, good idea but wrong location. You cant use any type of large furniture the way it is. I want to turn it around and put it on the wall instead of right in the middle. Its direct vented straight up so i would have to vent it with some 90 degree elbows to go out the same chimney and with the HOA theres no way they would let me punch a new hole.
Old 05-31-2011, 05:48 AM   #6
DIY staff
Rewards Points: 7,174
I suggest that you call a fireplace installation company---They will know the specs on the unit and have the insurance needed to do the job.
Your HOA will not allow you to DIY this job,I;m sure. Done incorrectly a carbon monoxide hazard will be created.
There are times and places where DIY is not an option--This is one of them.---Mike---
Tags
fireplace , remodel
Fireplace remodel cfurball Remodeling 3 04-10-2011 09:12 AM
Fireplace remodel CHINITAM Building & Construction 1 01-28-2011 11:06 PM
Fireplace remodel -- need advise & suggestions mwehnes Building & Construction 12 06-28-2009 09:36 PM
Help with an old fireplace remodel Atomikk Building & Construction 3 10-15-2008 02:44 PM
Fireplace Surround Remodel baksdak Project Showcase 5 03-06-2008 12:28 PM
