Moving A Load Bearing Stud - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 12:00 PM   #16
Registered User
Rewards Points: 5,216
A header is a lot of work especially in-place of the top plate, rather than under it..... Why not just add studs under each joist where there is a single top plate?
Be safe, Gary
Old 02-20-2010, 12:11 PM   #17
He said he wanted to open up the area under the stairs
Putting a stud under one of the joists would block that access
Old 02-20-2010, 02:43 PM   #18
Well what I really wanted to do was just take out the far left stud and stick a new one under the last ceiling joist. My issue was I did not know how to properly do it, and I also do not know where I would anchor the top of the staircase: if I could do it in the next over ceiling joist (not pictured), or what.
Tonglebeak is offline   Reply With Quote
Old 02-20-2010, 03:14 PM   #19
Be safe, Gary
I second this.
Put a stud under each joist, lose the crap to the left.
But leave in that stud behind the others that appears to be holding up the staircase. Then take more pics.
Dairylander is offline   Reply With Quote
Old 06-24-2010, 09:50 PM   #20
Of couse my mind changed quite a bit and today I finally stuck some studs under there (yes after 4 months, I'm lazy/distracted).
So all I'm really left now are the joists to the right. It wouldn't make sense to stick studs under there (or else there'd be no way to get to the stairs), and there is only 6ft of headroom _without_ a header.
You can see one of the joists in the pic, and then there's..2 more to the right of it, all nailed to an old rim joist. (the joist in the top right is nailed to the _side_ of this rim joist, as pictured earlier in this topic).
To me, it would see adequate to stick one more stud, under that 3rd joist. The problem is, the stairway rail is directly under it. I really don't want to tear it apart, but I presume I don't have any other option. Does anyone else agree?
Old 06-25-2010, 08:55 AM   #21
You say the rest of the green ceiling joists to the right butt into the rim joist.
If that rim joist is solid and supported, then I would just throw some joist hangers under the green ceiling joists to attach them better to the rim joist and forget about adding more studs.
Old 06-25-2010, 01:58 PM   #22
That's the problem though. It's not solid and not level. Post #14 has the pics of that joist in question.
Old 06-29-2010, 01:24 AM   #23
Pictures are worth a thousand words I guess. Bear with me, these should show a bit more detail into the rest of the problem:
This picture shows where the rim joist changes. It's very obvious. Please note that this appears to "attached" to the right-hand rim joist, by nothing more than a single nail going through the side of the joist, into the end-grain of the right-hand rim joist. If it's attached to the other one...well I don't know. Note that it does not appear to actually be sitting on the trim piece that runs under the joists.
And here is that joist in relation to the staircase banister. The cable line just so happens to draw the line where I want to sit the stud (On top of the 1st floor joist, under the 2nd floor joist that we're questioning):
I guess the only thing stopping me is the fact that I don't know how to cleanly disassemble the banister. I'm also not entirely certain if the right-hand rim joist is tied to the left-hand rim joist. If so, I may be in a world of hurt if I cut the diagonal stud that runs under the banister, and is tied to a 1x that is next to the new stud in the picture. Who knows if it's carrying a load or not lol.
I'm hoping to stick a stud under there and use it to jack up that joist just a bit (it causes a sag that runs parallel between joists). I'm going to be fighting some old wood though: the joist to the right (not visible) is twisted. Guess it happened over time since the joist I want to shove a stud under, isn't adequately supported (in my eyes).
So basically, I want to stick a stud (maybe two studs: one for that joist, and the other for the old rim joist to level that out) where the banister runs. Dig?
Old 06-30-2010, 09:48 PM   #24
Anyone?
Old 07-05-2010, 11:38 AM   #25
Well in any case, I screwed a 2x4 block to the underside of the joist (poor drill bit). Stuck another block on the floor (very close to its midspan support, so I'm good here), and start driving a stud up to jack the joist. Things are slowly leveling out, just gotta figure out how to make it permanent in the end.
Old 07-05-2010, 03:31 PM   #26
Registered User
Just cut back the floor joists enough to attach a header joist above the banister bearing at the last new stud and the landing wall. Double it if needed then add hangers to the floor joists. The pieced rim would stay (alongside) with the new double on the joist side.
Be safe, Gary
Old 07-05-2010, 04:03 PM   #27
Ah, yes I understand what you're saying. Will just need to temp support the 3 joists then correct?
Old 07-05-2010, 04:49 PM   #28
kwikfishron's Avatar
Rewards Points: 176
Yep.
kwikfishron is offline   Reply With Quote
Old 07-05-2010, 06:41 PM   #29
Awesome. One final question before I do this:
It's going to be a little over 6 and a half feet from bearing point to bearing point. Will a single 2x8 sufficiently carry two joists (after looking carefully, the 3rd joist is actually held up by the exterior wall, so that's one less to worry about), or is doubling the way to go for sure? Thanks.
Old 07-05-2010, 09:40 PM   #30
Registered User
1. What load is above the pieced rim? Another stairs/wall, or stairs/pickets?
2. What is the span of the soon-to-be-shortened-for hangered joists?
3. Are there any point loads on those joists?
Be safe, Gary
damaged load bearing stud, next to a window danf01 Carpentry 1 10-12-2009 07:02 AM
Moving studs on load bearing wall for HVAC? grouse Building & Construction 1 08-20-2009 03:16 PM
Moving Load Bearing wall in Basement iqkhn Remodeling 4 04-05-2009 05:53 PM
Cutting a stud on load bearing wall timw Remodeling 5 01-12-2009 02:55 PM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
