Moving A Doorway In An Exterior Brick Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 04:15 PM   #1
Rewards Points: 45
Moving a doorway in an exterior brick wall
As crazy as it may sound, I'm planning to move the doorway to the carport from the laundry room to the kitchen. The laundry room is very tiny and does not make for much of an entrance to the house so I will be changing it so that you walk directly into the newly remodeled kitchen. The exterior wall is a 2x4 insulated wall with brick facing. The house was built in 78' and luckily the previous owner kept several extra bricks so I wont have to worry about matching the color of the existing ones. I know that I will have to cut out the concrete door ledge of the opening that is being covered and pour a new concrete ledge for the new opening. I will be reusing the door and frame for the entrance to the kitchen which is a 32" door.
Anyway, I have a few questions about the project:
-When I brick up the old opening, do I need to take down the 4 or 5 rows of bricks above the opening or can I somehow squeeze all of the new bricks in?
-Do I need to install brick ties that connect the new bricks to the framing? If so, what is the spacing?
-Will I need to install a steel angle iron brace to hold up the layers of bricks over the new opening? If so, how do I get it in there with out taking all the top bricks down?
Any other hints/suggestions are greatly appreciated. Oh, forgot to mention, I've never worked with brick and mortar before.
Matt
Lafayette, LA
GeauxCajuns82 is offline   Reply With Quote
Old 01-03-2011, 04:25 PM   #2
If this is an opening that you're going to be walking past every day, then my tip is to get a professional to do it.
Bad brick is forever.
pyper is offline   Reply With Quote
Old 01-03-2011, 08:21 PM   #3
Concrete & Masonry
Rewards Points: 620
That is really an aesthetic question, and depends on the brick coursing heights. If there's only a few course above the door, I would take them down & remove the angle for use on the new opening, if possible.
Yes, a good rule is 2 sq. feet maximum per wall tie, which typically equates to 16" centers both ways. More won't hurt either, and be sure to get 7" galvanized, 22 gauge minimum for the ties.
Yes, and you don't. You need to take enough courses out above to fit the angle iron lintel to make the job look decent. If there is a lot of brick above, you may need an additional angle iron to slide in backwards (upwards leg facing out & up) to temporarily carry the weight.
Sure. Take your time, it's going to take at least 2-3 times longer to do a good job than you currently envision. This kind of brick work is slow & tedious, even for a mason like myself who's done ton's of "tooth'in's" in his career. Also, make sure you have at least 25-50 extra brick before you start, because your guaranteed to break some of them, it's just how many is the question.
Good luck.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
GeauxCajuns82 (01-05-2011)
Old 01-04-2011, 07:54 AM   #4
Rewards Points: 582
When bricking up the old doorway you could consider stepping the brickwork back from the existing brickwork as shown in the photo for window frames, although this is a feature used on door openings as well.
This method is actually a feature used on new builds here.
The advantage for using it on an existing doorway is that no toothing is required, and even if the bricks and mortar don't quite match it doesn't look out of place.
As Jomama has said, it's really difficult even for a mason to get it looking right.
stuart45 is offline   Reply With Quote
Old 01-05-2011, 04:39 PM   #5
Rewards Points: 45
Thanks for the suggestion, Stuart, but I want the wall to look as if there was never a doorway there.
And thanks for the info jomama. However, the more I research this the more I'm considering hiring a brick layer to do this. Any idea how much something like this would cost?
One more question though: is there a a maximum number of layers you can do at a time so that the mortar from the bottom bricks doesn't start to squeeze out from the weight of the upper rows? The exterior wall is just over 7 feet tall.
Matt
Lafayette, LA
Old 01-05-2011, 04:53 PM   #6
Rewards Points: 582
It depends on the type of brick used. On site with your average face brick 5ft a day was the normal allowance. With a heavy engineering brick a couple of ft was usually enough. Most bricklayers would probably want to build in the frame in the same day.
How are you doing the new opening. Cutting out with an angle grinder, or making a larger hole, toothing out and building in the frame?
Old 01-05-2011, 05:16 PM   #7
Rewards Points: 150
If you do attempt this job, remember, the mortor must be mixed so it'll support the brick, like in not runny. Keep track each mix on the ratios. Some brick you can't use muratic acid to clean up when finished, and be careful with the acid with kids around. Use a straight edge to span the opening and tooth in the brick. You can do it ,just step down and take a look now and then.
bernieb is offline   Reply With Quote
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 05:48 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Doorway though brick wall. archangel689 Building & Construction 3 04-20-2007 09:23 AM
