Old 08-23-2011, 01:29 PM   #1
Moving Cabin from crawlspace foundation to slab
New to the forum - looks like a great resource!
I am in the process of moving a cabin (36 x 24 single story) in northern MN from a crawlspace foundation to a monolithic slab foundation. We are putting the slab directly in back of the existing foundation and moving the cabin on to it. My question.
The cabin has a traditional floor system - 2 x 10 floor joists. What would be the best way to set this on the slab?
Ideally, I would like to remove the floor joists and set the frame of the cabin directly on the slab. This would give me a concrete floor. This seems complicated.
If I keep the floor joists what would be the best method to set this on the new slab? I assume I cannot just set the joists directly on the concrete? The current joists are not pressure treated.
As additional information - I will be completely remodeling the cabin after it is moved (Including removing the subfloor).
Hopefully my questions are clear and thanks in advance for the help!
rgood44 is offline   Reply With Quote
Old 08-23-2011, 07:50 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Well a lot depends on how your floor and your walls systems are constructed.
I am assuming there are bottom plates for the walls that sit atop a sub-floor decking material, (ply, diagonal 1x?) That are nailed to FJs (floor joist).
I might start by re-enforcing the walls for shear while moving, suspend the structure in some way (many different ways) remove the sub-floor and FJs.
Install new pressure treated (PT) sill plates on the slab with the appropriate hold-downs long enough to go thru the new sill and the old sill plates.
These are just vague suggestions I know but your question lacked any specificity also.
Andy.
AndyGump is offline   Reply With Quote
Old 08-23-2011, 08:37 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
The best way is to number all of the logs, and reverse the process that was used to put it together. Log cabins are a creature of their own, and just moving them can be enough to cause the logs to shift, and the chinking to pop out. I would suggest contacting the company that built this home, or talk to a architect that is familiar in this type of construction.
Slab Foundation Repair dtsman General Discussion 1 06-10-2011 09:54 PM
monolithic slab foundation verses crawlspace foxcar59 Building & Construction 1 10-27-2010 12:26 AM
rotten foundation form ties = crawlspace leaks? acordeon Building & Construction 5 09-26-2010 10:36 PM
Moving a gas line when house is on a slab Socrmom3 Appliances 4 01-24-2008 12:32 AM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
