Move Drain Pipes To Get XPS Insulation Behind? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 09:29 PM   #1
Move drain pipes to get XPS insulation behind?
I am putting together plans to finish my basement and am going to go the 2" XPS foam route. I have several drain pipes running along the wall. Do i need to move these or do i insulate around them?
ryanmcl is offline   Reply With Quote
The Following User Says Thank You to ryanmcl For This Useful Post:
jimhandyman (01-06-2013)
Old 01-06-2013, 09:47 PM   #2
I would prefer to insulate on the cold side of any water pipe otherwise it could freeze up.
jimhandyman is offline   Reply With Quote
Old 01-07-2013, 05:14 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
If its waste or vent, I get my xps as close as I can then fill the gap with canned foam.
12penny is offline   Reply With Quote
Can I move this drain over without issue? hpsguy Plumbing 8 01-03-2013 12:20 AM
Breaking out concrete to repair old shower drain pipes? darsunt Concrete, Stone & Masonry 4 11-07-2012 07:39 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Water pipes behind basement insulation ariapn Remodeling 6 04-02-2010 09:28 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
