Mounting Something To Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 01:34 PM   #1
Rewards Points: 260
Mounting something to trusses
Can you mount an air handler to the middle of trusses? These are normal 2x4 trusses. Normally, the air handler would sit on the bottom of the trusses (perpendicular to the trusses) right above the drywall. There isn't that much room between triangles. Can something be mounted higher up in the middle of the trusses? Have you seen anything like this? We're talking about 100 to 200 pounds spread out between 3 trusses.
bluefitness is offline   Reply With Quote
Old 07-19-2009, 07:11 PM   #2
Registered User
Rewards Points: 5,216
Check the spec's of the trusses or contact the manufacturer. Unless they were designed and loaded for the extra weight, I doubt anyone would take the liability. Be safe, G
Building Garage with Engineered Trusses twiles Carpentry 30 03-12-2016 09:17 PM
Pre-Manufactured Trusses or not? my5sons Building & Construction 7 04-13-2012 01:44 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 09:47 AM
Joists - TGI vs. Web Trusses handy man88 Building & Construction 3 04-02-2007 12:34 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
