Mounting Buck Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2009, 02:17 PM   #1
mounting buck boards
We are getting ready to keep critters from getting into our house that is under construction. We are wanting to tack up clear plastic over the concrete window and door openings. Since we are not sure right now what exterior (if any) will cover the concrete block then is it safe for me to install the buck boards in the window and door opening flush with the outside edge of the block ?
Also is there anything I need to make sure is in place before I mount the boards into place or can the flashing and evrything be done later ?
Mudball is offline   Reply With Quote
Old 08-15-2009, 03:29 PM   #2
I found the answer to one of my questions. I guess I was searching the internet with the wrong words. It seems I will be mounting the edge of the pressure treated wood flush with the outside edge of the block. I cant help but believe the same will be done for the door opening as well.
Old 08-15-2009, 06:32 PM   #3
Registered User
Rewards Points: 526
Be sure to use some poly sill sealer or foam under the p.t. from a box store to keep the little creepy crawlers out, too.
Be safe, G
Old 08-15-2009, 07:01 PM   #4
That sounds like good additional insurance.
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 11:09 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 06:59 PM
