Old 01-21-2013, 07:09 PM   #1
Mounting a bathroom fan on a vertical wall?
I'm building a three piece bathroom in my basement. I'm having difficulty finding a fan that will fit in the ceiling rafters because I've got heating ducts in the way. I could easily fit it on the back wall but I'm not sure if that would provide enough sucking power. I'm mostly concerned about venting steam from the shower.
Will it work well enough if it's installed on a vertical wall or would I be better off finding something that will fit into the ceiling?
Evilhomer is offline   Reply With Quote
Old 01-21-2013, 07:18 PM   #2
One in the ceiling would be be best. Panisonic makes some where the motor can be mounted remotly.
Old 01-22-2013, 08:36 AM   #3
There are fans designed for vertical mounting, but I've never seen any except in hotel rooms.
Old 01-22-2013, 08:38 AM   #4
And old mobil homes over the stove.
Not a great look.
Old 01-22-2013, 10:03 AM   #5
http://www.panasonic.com/business/bu...isper-wall.asp
russiand is offline   Reply With Quote
Old 01-22-2013, 10:35 AM   #6
Not so new
12penny's Avatar
Ive done this a couple times. Google " in line fans". They're the same as a radon system fan.
12penny is offline   Reply With Quote
Exterior Bathroom Wall Insulating dvaupel Insulation 15 10-07-2011 10:59 AM
Hanging / Mounting a 6' x 3-1/2' 250lb water wall? robsworld78 Building & Construction 13 08-19-2011 09:59 AM
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 10:28 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 11:14 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
