Mounting 4x4 Wood Post To Concrete Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 09:49 AM   #1
mounting 4x4 wood post to concrete porch
I have a concrete front porch with medal post holding up the porch roof. I want to replace the medal post with 4x4 wood post and put up raillings. I am not sure how the mount the wood post to the concrete porch. Any help would be appreciated.
pshinaults is offline   Reply With Quote
Old 05-27-2010, 03:53 PM   #2
Household Handyman
Rewards Points: 1,408
If you are asking about mounting the bottom of the 4 x4 to the concrete porch, there are various ways. This will depend on whether or not you want to see any mounting plate or just the post meeting the concrete of the porch. There are many types of mounting plates which the post will sit on and the attach to the concrete, leaving some gap at the bottom to prevent water from building up under the post. I have used a method of drilling into the post, drilling into the concrete, and then screwing a large lag bolt into the post, cutting off the head, and installing the bolt into the hole in the concrete with some epoxy to prevent it from shifting. Whatever the customer wants. Using proper support techniques to lift and hold up the porch will be the main concern here while doing the work. David
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 6 04-01-2010 07:41 PM
How to secure bottom of 4 X 4 post to concrete? darsunt Building & Construction 6 08-19-2009 08:36 PM
help on verticle siding on concrete porch LeftyLucy Building & Construction 2 08-08-2009 10:03 AM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 05:47 PM
